horn in engine bay?
anyone have any pics of where the horn should be in the engine bay
i tried to hook up the horn in my eg i just bought
and its not working anyone know where the horn is?
i found it behind the bumper under the radiator on passanger side
its not working i check the fuse not blown power is going through
i really cant check the wires b.c its soo hard to get too unless i take the radiator out
any ideas?
any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ran4it2 »</TD></TR><TR><TD CLASS="quote">i found it behind the bumper under the radiator on passanger side
any ideas?
If you still have your SRS cable reel (behind your steering wheel), take one of the horn plugs (black plug, two red wires), and bridge them with a paperclip. If your horn works, it's most likely that your button is broken.
any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ran4it2 »</TD></TR><TR><TD CLASS="quote">i only have one wire its white
the car has a momo steering wheel
i thought the white was power so i grounded a wire and tried and it didnt work
The white is ground to the hub. You'll need to run wires for the horn from the plug your cable reel would plug into.
For the record, I could never get my MOMO horn to work, but I believe my horn button was broken. It wouldn't close the circuit inside the horn button itself.
VTECsound
22
Oct 20, 2005 08:31 PM
FBP Si 2000
14
Dec 23, 2001 07:54 PM
