Poweder coating intercooler?
Old Jun 2, 2002 | 06:08 PM
b00stedsi's Avatar
Default Poweder coating intercooler?
I want my intercooler to be black for steath purposes. Any suggestions.....
Old Jun 2, 2002 | 06:11 PM
Jared's Avatar
Default Re: Poweder coating intercooler? (turkish)
My suggestion is don't do it. Black absorbs heat and is a step backwards from the original purpose of the intercooler. Put some grill mesh in front of it and paint the grill mesh black.
Old Jun 2, 2002 | 06:12 PM
int3gra's Avatar
Default Re: Poweder coating intercooler? (Jared)
i agree
Old Jun 2, 2002 | 06:23 PM
ion_four's Avatar
I don't think it being black would have any noticeable effect on the cooling (it won't be in the sunlight much at all) but, having it painted might not let it cool as well, though if you coated the backside of the intercooler and endtanks you might be slightly better off, since it wouldn't absorb any heat from the engine/radiator.
Old Jun 15, 2002 | 09:58 PM
AGen2integra's Avatar
Default Re: Poweder coating intercooler? (ion_four)
I know this post is old........but, Doesn't someone make a radiator paint you could spray your intercooler with? I want that stealth/sleeper look (with the black intercooler) and I would think if you used something like that it would not affect the cooling of the air. What do you guys think? Thanks, Evan
Old Jun 15, 2002 | 11:20 PM
BoostinDC2's Avatar
Default Re: Poweder coating intercooler? (AGen2integra)
i dont think painting it black would affect the cooling. i mean why would stock ic's come black from the factory i.e. skyline gtr
Old Jun 16, 2002 | 12:10 AM
ninesecrx's Avatar
Default Re: Poweder coating intercooler? (BoostinDC2)
Painting the intercooler will not hurt any cooling. All an intercooler is is a big heat sink. The air will still flow through it and the metal will still let out the heat. I even read it in the Spearco manual I have......Mike
Old Jun 16, 2002 | 01:55 AM
Stock@$$GSR's Avatar
You could send it to Swain to have it coated with this black stuff that actually helps with heat dissipation. It costs around $150.
Old Jun 16, 2002 | 09:35 AM
PrecisionH23a's Avatar
Default Re: Poweder coating intercooler? (Stock@$$GSR)
there was a topic on this before, i cant find the thread though. the guy ended up painting his ic black, it turned out looking really good. every mod has its pro's and con's, in the end its really all about preference. to each his own.
Old Jun 17, 2002 | 12:40 PM
supergreenNA1's Avatar
New User
get it anodized black.
Old Jun 17, 2002 | 02:32 PM
Thrillhouse's Avatar
Default Re: Poweder coating intercooler? (supergreenSol)
dont they have heat resistant paint?
Old Jun 17, 2002 | 02:33 PM
Default Re: Poweder coating intercooler? (Thrillhouse)
or paint it black and get nitrous express...
Old Jun 17, 2002 | 03:14 PM
JustChou's Avatar
If I'm not mistaken, powdercoating is a bit different from paint, the main difference being that it's thicker. I do believe this will act as a heat blanket and keep some of the heat in. However, anodization is a great option since all IC's are aluminum.
Anodization is a process in which the outer layer (very thin, around .003" I think) of an alumium surface is oxidized into Aluminum Oxide (go figure). In this process, dyes can be added to the aluminum to give it a colorful, yet still metallic sheen. Aluminum "billet" shift ***** which are blue and red are a result of anodization.
Old Jun 18, 2002 | 10:41 AM
JustChou's Avatar
Default Re: Poweder coating intercooler? (JustChou)
Also, take note that most heatsinks are annodized black. This is another indication that this is a good idea.
Turbo Neon
Nov 5, 2007 04:53 AM
Brnymac
Mar 9, 2005 09:33 PM
mrod006
Jan 25, 2003 09:16 PM
LostLude
Jan 12, 2003 12:58 PM
KevronsEG
Aug 4, 2002 07:27 PM
