Made my own D Series Crank Pulley Holder
Old May 24, 2007 | 03:45 PM
Sketch_hs's Avatar
Default Made my own D Series Crank Pulley Holder
Well i needed to get it done to day, so with about $10 worth of home depot parts and about and hour with a drill, hack saw, and welder...
Gentlemen I give you:
PULLEY BUSTER 5000!
Worked like a charm both on this motor on the ground and one in the car
Old May 24, 2007 | 04:00 PM
93supercoupe's Avatar
Default Re: Made my own D Series Crank Pulley Holder (Sketch_hs)
nice work brotha, i had a Dseries pulley bolt back out over 100 miles from home.
I had to borrow a car, drive from mass to ct, JUST TO GRAB THE WRONG bolt.(for a B)
I took the D out and put a LS in.
Old May 24, 2007 | 04:22 PM
Sketch_hs's Avatar
Default Re: Made my own D Series Crank Pulley Holder (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">nice work brotha, i had a Dseries pulley bolt back out over 100 miles from home.
I took the D out and put a LS in. </TD></TR></TABLE>
Torquing them is easy lol i just use my impact
this is really for the removal of bolts my impact wont take off
i was jumping up and down on a 6ft bar and using this tool to break those two bolts loose
lol
Old May 24, 2007 | 07:49 PM
BIGTUNA's Avatar
Why not just use a chain wrench?
Old May 24, 2007 | 10:16 PM
cua0's Avatar
Default Re: Made my own D Series Crank Pulley Holder (BIGTUNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGTUNA &raquo;</TD></TR><TR><TD CLASS="quote">Why not just use a chain wrench? </TD></TR></TABLE>
just on the off chance that he wants to use the pulley again i'm sure..
Old May 25, 2007 | 06:29 AM
Shaun_'s Avatar
Default Re: Made my own D Series Crank Pulley Holder (cua0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cua0 &raquo;</TD></TR><TR><TD CLASS="quote">
Ahh i used a chanin wrench on my B series pulley. I would suggest getting an old belt to wrap around it first though. It slightly marred the ribs on the pulley.
Old May 25, 2007 | 10:19 AM
Sketch_hs's Avatar
lol
pulley buster 5000 FTW!
its so easy to use thanks to the 4 foot arm
Old May 25, 2007 | 10:52 AM
Bakeoff's Avatar
I've seen setups like that, that have cracked the pulley at the holes...
I just yank off the dust cover on the flywheel, and use a screw driver between teh flywheel and bell housing. Works great every time.
Old May 28, 2007 | 12:09 PM
md88hfcrx's Avatar
that woulda came in real handy a few weeks ago. i just needed the bolt and lock for another setup. ended up buy a new one.
Old May 28, 2007 | 03:27 PM
SECURITY's Avatar
Default Re: Made my own D Series Crank Pulley Holder (md88hfcrx)
Small world, I just made one of these today, cost was a whopping $2. I'll post pics later
Old May 29, 2007 | 05:54 AM
sleepencivic's Avatar
Default Re: Made my own D Series Crank Pulley Holder (SECURITY)
i just stick a pry bar on the flywheel teeth and break it loose
Old May 29, 2007 | 06:04 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SECURITY &raquo;</TD></TR><TR><TD CLASS="quote">Small world, I just made one of these today, cost was a whopping $2. I'll post pics later</TD></TR></TABLE>
GROUPBUY!
I just bought a JDM H22a and I don't this crank bolt was ever removed! It's the bolt from hell! Tried heating it up, impact gun (probably need a bigger compressor though, just a 3hp, 20 gal Craftsman compressor). My next and last hope is to build a 6 ft breaker bar and jump on it to get it off.
Old May 29, 2007 | 11:08 AM
Default Re: Made my own D Series Crank Pulley Holder (Finest)
use some pb blaster...it will come off
B18CUL8R
May 3, 2008 04:55 AM
xplicitrix
Feb 29, 2008 03:50 PM
budomove
Nov 2, 2007 07:37 PM
airwalk07143
Jul 26, 2004 08:58 PM
