spec stage 3 clutch in my 2004 accord v-6 just a ?
Old May 24, 2007 | 03:12 PM
tlmg21700's Avatar
Default spec stage 3 clutch in my 2004 accord v-6 just a ?
i recently burnt out my stock clutch and i purchased a spec stage 3 with no springs in the clutch disc i just want to know if anyone had one and how was the experience let me know thanks tony
Modified by tlmg21700 at 4:58 AM 5/25/2007
Old May 24, 2007 | 06:40 PM
-RedneckDave-'s Avatar
Working
Default Re: spec stage 3 clutch in my 94 accord v-6 just a ? (tlmg21700)
There was not a v6 manual in the 94 accords. What car do you have?
Old May 24, 2007 | 07:09 PM
gianinline's Avatar
i was wondering the same thing about the title....
there was no 5th generation V-6 or even a 6th generaion V-6 that had a manual transmission. Started only on 7th generation!
Old May 25, 2007 | 03:09 AM
streetxdreamer's Avatar
Default Re: (gianinline)
i think the 5th gens did have a v6 with a manual tranny
Old May 25, 2007 | 05:45 AM
twkdCD595's Avatar
Default Re: (streetxdreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetxdreamer &raquo;</TD></TR><TR><TD CLASS="quote">i think the 5th gens did have a v6 with a manual tranny
thats news to me... no manual tranny was offered in a 5th gen accord v6 as far as I know and needless to say the 1995 was the first year option for the v6 anyways.
ANYWAYS... the OP looks like made a mistake on their year... if you notice the title of the thread has been edited. Unfortunately the edit only shows once you clip into the thread and reread the title on the first post... but from the main forum view it is not.
So back to the topic. I had a spec stage 3 4 puck in my boosted 95... not a bad clutch for the money, just did not last long. I only got a couple thousand miles of it before it started slipping (which was right after I retuned for more power)... I may have overpowered the clutch.
I would not have went with the solid hub for a daily driver street car personally cause it will be a bit more rough engaging than a sprung hub... may have a bit more chatter as well. You should be fine though, once you learn to drive on that style clutch it wont be too bad. It will definately be alot more aggressive than stock. Pedal feel on the spec is not too bad though, just slightly stiffer.
Modified by twkdCD595 at 9:15 AM 5/25/2007
Old May 25, 2007 | 06:18 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">ANYWAYS... the OP looks like made a mistake on their year... if you notice the title of the thread has been edited. Unfortunately the edit only shows once you clip into the thread and reread the title on the first post... but from the main forum view it is not.</TD></TR></TABLE>
I fixed that
Old May 25, 2007 | 09:12 AM
msedacca's Avatar
Default Re: spec stage 3 clutch in my 2004 accord v-6 just a ? (tlmg21700)
I have a Spec Stage 3 clutch in my 4CYL 04 and no problems. I had no problems, but I my flywheel (comptech tsx ) to be machined together with the clutch at Spec, so no help there, just bolted it up fine.
Old May 25, 2007 | 09:48 AM
Working
Default Re: spec stage 3 clutch in my 2004 accord v-6 just a ? (msedacca)
We used Spec exclusively on our race car when I was home and we had a very good experience so far. Right now we have their triple disc and it is holding the 800+ hp very well.
Destructosaur
May 13, 2005 11:23 AM
One2chi
Mar 18, 2003 03:06 PM
HondaTypeS
Sep 22, 2002 06:46 PM
