crooked motor
Old May 24, 2007 | 01:50 PM
everythingwentblack's Avatar
Default crooked motor
i have a 94 civic coupe that i switched from auto to manual. When i did the conversion I swapped the motor with another D15B and went through a **** load of mounts before i realized the tranny (passenger side) bracket was higher (originally to accodmodate the automatic tranny). Long story short it drives fine but now that I am going to finally lower it and do a b16 swap i wasnt sure if the crooked motor would cause my axles to bind up. Has anyone else had this problem?
Old May 24, 2007 | 02:12 PM
g23_ej1's Avatar
Default Re: crooked motor (everythingwentblack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by everythingwentblack &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 civic coupe that i switched from auto to manual. When i did the conversion I swapped the motor with another D15B and went through a **** load of mounts before i realized the tranny (passenger side) bracket was higher (originally to accodmodate the automatic tranny). Long story short it drives fine but now that I am going to finally lower it and do a b16 swap i wasnt sure if the crooked motor would cause my axles to bind up. Has anyone else had this problem? </TD></TR></TABLE>
i would say so.. so you didnt drill out the old bracket and reweld it to where it needs to be?? didnt bother to buy the auto-manual mount?? mightest well just spend a little more time at it to get it 100% because i see problems in the future.. axle binding, exhaust mani not lined up, possible problems with shift linkage, and lots of others.. the motor is straight from the factory for a reason
Old May 24, 2007 | 02:23 PM
philosofy1's Avatar
i wouldn't recommend driving any motor sitting crooked under the hood. invest in getting the auto - manual tranny mount.
Old May 24, 2007 | 02:49 PM
Luserkid's Avatar
Default Re: crooked motor (philosofy1)
For 92-95 Civics you need an Auto To manual mount or drill and reweld.
Old May 24, 2007 | 03:21 PM
where can i get the auto to man mount?
Old May 24, 2007 | 04:38 PM
Luserkid's Avatar
Default Re: (everythingwentblack)
Hasport
Old May 24, 2007 | 04:46 PM
9200RPM's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Hasport </TD></TR></TABLE>
sambo351
Aug 15, 2008 09:48 PM
everythingwentblack
May 23, 2007 09:09 PM
gray_civic_coupe
10
Sep 18, 2005 12:47 AM
streetlegal gocart
Feb 18, 2005 07:27 AM
StevenD
Jun 4, 2004 02:17 AM
