FS: 95 Del Sol, B16, konis, etc. - Triangle, NC
Old May 24, 2007 | 01:11 PM
Dave421's Avatar
Default FS: 95 Del Sol, B16, konis, etc. - Triangle, NC -SOLD
<U>
SOLD!!!</U>
FS: 95 Honda Del Sol $5400 obo.
Contact: Dave421 AT gmail DOT com
I've decided to put my Del Sol up for sale. I just picked up a new project and a daily driver and I just don't have room for it. The car is in great condition and has been very well maintained. Oil has been changed every 3000 miles with Mobil 1 synthetic. The car is running a JDM B16 motor purchased from Japan Direct here in Raleigh. Car has 160k on chassis and motor is around 80k miles. The car only has 2 issues. Someone backed into my fender in the parking lot the other day and dented the pass. side fender. A new fender can be bought and painted for $160. The only other issue is 3rd gear grinds when shifting quickly. Otherwise, the car runs like a top. I just put a new fuel filter & spark plugs in today. A new clutch slave cylinder, battery, valve cover gasket, transmission fluid, & vtec solenoid gasket have been put on the car this year. I've only driven it a few hundred miles this year since I picked up my daily driver but the car is started and driven around once a week to keep everything in shape. The car is set up for handling with koni sport (yellows) shocks, rear sway bar/tie bar, f&r upper strut bars, and lightweight 15" Rota Circuit 8 wheels. I also added a lot of JDM items to this car that are very hard to come by (map lights, visors, taillights, Gathers rear speaker covers, etc.). Links to the pics are below along with the whole list of modifications.
Please email with any questions.
Engine
B16A from Japan Direct
LS cable tranny
Hasport Hydro-Cable Conversion
Toda flywheel
ACT 6 puck sprung hub clutch with heavy duty pressure Plate
Unorthadox race only crank pully
Chipped P28 with upgraded b16 map
2.5" custom exhaust with straight through turbo muffler
C's shifter
AEM Fuel Pressure Regulator
DC Sports Header
AEM Intake
Plug Wire Cover
Fuel Pressure gauge
Ground Wire Kits
New Timing and Water Pump
NGK Japanese 8mm plug wires
High Flow Cat
Full-tune up
New Valve cover gasket
New v-tec slonoid gaskets
Brand new battery
Suspension
Custom Front Traction Bar
Koni yellows
no name coilovers
JDM Type R front strut tower bar
rear upper and lower bars
Rota circuit 8's 15"
Hawk HPS brake pads
GSR front brake assembly
Del sol vtec rear brakes
Extended Front Studs
Body
Body in great condition with a few small dings and a small hit in the passenger fender
Carbon Fiber Hood
JDM sidemarkers
JDM Tail lights
Black aftermarket headlights and corner lights
Antenna delete plate
small hole in firewall from old clutch cable
Custom Washer Nozzle placement
Interior
JDM Map lights
JDM Gathers rear speaker covers
JDM leather seats (drivers a little worn)
JDM Visors
JDM Upper gauge Cover
Full black interior minus door panels
2 JL 8w0's in a custom fiberglass box wrapped in vinyl
Rockford amp
Custom mounted tweeters
3-gauge A-pillar pod
oil pressure gauge
air/fuel guauge
Battery guage
V-tec 9200 RPM Bezel
*edit* lowered price.
Modified by Dave421 at 2:20 PM 5/27/2007
Modified by Dave421 at 5:48 PM 5/31/2007
Modified by Dave421 at 8:06 PM 7/1/2007
Old May 25, 2007 | 09:55 AM
Dave421's Avatar
*bump*
Old May 26, 2007 | 06:24 AM
Dave421's Avatar
Somebody make me an offer. Need to get rid of this thing. Too many cars and not enough room!
Old May 27, 2007 | 10:08 AM
Dave421's Avatar
*bump for new price. $5700
BUY ME!!!
Old May 31, 2007 | 01:48 PM
Dave421's Avatar
lowered priced to $5400
Old Jun 5, 2007 | 07:12 AM
Dave421's Avatar
*bump* BUY ME!!!!!!!!!
Old Jun 27, 2007 | 07:10 PM
eg-coupeBseries's Avatar
Default Re: (Dave421)
woul you take 5?
Old Jun 27, 2007 | 08:43 PM
Dave421's Avatar
car is pending sale right now. I'll let you know if it falls through.
Old Jun 28, 2007 | 03:17 PM
alright
Old Jul 1, 2007 | 04:06 PM
Dave421's Avatar
Car is sold!
Blacksole
Jan 11, 2012 12:37 PM
2006ser
30
May 7, 2011 06:35 PM
NACvicSi
Southeast (Sales)
Nov 13, 2007 11:32 AM
