speedo not working....throwing a vss chekc engine light...how to fix
well my speedo and odometer aren't working...when i jump the the code it says that it is the vehicle speed sensor... i just replaced the sensor and the damn thing is still throwing the code and i have no speedometer..plz throw smoe info at me to help...thanks
When go through the step-by-step troubleshooting procedure in the Helms manual, where do you get stuck?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">You have to reset your ECU when you fix anything. Where did you get the VSS from??</TD></TR></TABLE>
not true, the code will be reset after a few consecutive drive cycles if the fault isnt present again.
most likely is a bad connection at the VSS or you broke the plastic gear installing it.
92_VX_EG
May 9, 2007 11:58 PM
ham
Apr 13, 2007 07:43 AM
type r 01-1063
Jan 16, 2004 11:52 AM
crxsi_rcr
Mar 20, 2002 06:08 PM
