speedo not working....throwing a vss chekc engine light...how to fix
well my speedo and odometer aren't working...when i jump the the code it says that it is the vehicle speed sensor... i just replaced the sensor and the damn thing is still throwing the code and i have no speedometer..plz throw smoe info at me to help...thanks
DixielandImports Please
Re: speedo not working....throwing a vss chekc engine light...how to fix (brentaction22)
First where did you get the VSS from?
Next did you reset the code?
Also what year car?
Also what year car?
When go through the step-by-step troubleshooting procedure in the Helms manual, where do you get stuck?
check to see if your rear o2 sensor wires is touching the heat shield and shorting out this happend to me and sounds likt the same problem also check your fuses
Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">You have to reset your ECU when you fix anything. Where did you get the VSS from??</TD></TR></TABLE>
not true, the code will be reset after a few consecutive drive cycles if the fault isnt present again.
most likely is a bad connection at the VSS or you broke the plastic gear installing it.
92_VX_EG
05-09-2007 11:58 PM
ham
04-13-2007 07:43 AM
type r 01-1063
01-16-2004 11:52 AM
