need some help, misfire/timing problem 94 b18c1 delsol
Old May 24, 2007 | 09:43 AM
vivid1's Avatar
Default need some help, misfire/timing problem 94 b18c1 delsol
alrighty guys, need a bit of help here. Not too familiar with hondas and the swaps. I didn't perform this swap, and I'm only working on it for a friend as I've done quite a few swaps, full builds and turbo setups on alot of 4 cyl chryslers.
Car i'm working with is a 94 del sol. It has a b18c1 engine, with a p00 computer (the computer has been chipped by TSR in glen burnie, md for a b18c1) . I have jumped the connector to get codes and all it shows me is map sensor, code 3(which I have replaced, and checked the wiring to check for resistance)
At idle the car has a very slight flutter, nothing too hateful but quite noticeable, almost like worn plugs but all are new, as is cap and rotor. I'm not positive what car the distributor is from, but I would guess it's a gsr distributor as well too.
Partial throttle with no load the car will rev out to redline, with a bit of misfire in the 800-1500 range and then totally clear and smooth.
Full throttle the car just dies. It's almost as if it's a mixture of flooding or that it's 180 degrees out. Backfires through the intake, strong fuel smell from exhaust at same time. I almost want to take it to a vet as it sounds like a dog getting hit by a truck as it stalls out.
Just need a bit of help on this one. I like challenges, but with a swap it's harder to hit up alldata and my other resources and get straight answers on it, so if anybody has some info on what to check and what to try next, it's greatly appreciated.
Old May 25, 2007 | 06:59 AM
vivid1's Avatar
Default Re: need some help, misfire/timing problem 94 b18c1 delsol (vivid1)
any ideas?
dc2much
Mar 17, 2010 07:19 PM
l337jdmride
Dec 24, 2009 06:51 PM
Caper79
14
Aug 27, 2009 11:22 AM
eclipsed95
Jan 13, 2008 05:30 PM
vivid1
May 25, 2007 06:26 AM
