LCA bushings
Got my new bushings from Energy Suspension and am just about to start installing them.
The instructions are pretty straight forward, but I'm still wondering if I need to keep the metal sleeve that's over the stock bushing, or if I take everything out?
The old metal sleeve must go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">you need that metal sleeve when you are done or the bolts will eat the bushings away.</TD></TR></TABLE>
What Dead is trying to say is that the new metal rod must be use.
If I press out the rubber, will the outer sleeve follow too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">The old metal sleeve must go.
What Dead is trying to say is that the new metal rod must be use.</TD></TR></TABLE>
Got ya
Got ya
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze_125 »</TD></TR><TR><TD CLASS="quote">If I press out the rubber, will the outer sleeve follow too?
Got ya
I Don't know. When i did mine. I didn't have access to a press. What i did was burn the old rubber then cut the sleeve with a hack saw.
Got ya
</TD></TR></TABLE>I Don't know. When i did mine. I didn't have access to a press. What i did was burn the old rubber then cut the sleeve with a hack saw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">I Don't know. When i did mine. I didn't have access to a press. What i did was burn the old rubber then cut the sleeve with a hack saw.</TD></TR></TABLE>
That's what I'm doing too... I was looking for an excuse to go get my-self a press... but it looks like I can do the job without it
What did you use to put the new ones in? Sledge hammer?
.What did you use to put the new ones in? Sledge hammer?
no no no no almost everyone are 2 peice units just grease them up good and push them in. you might need to be tapped in. The ones that are 1 piece will need to be pressed in but there were only 6 in my kit that where that way
BDogggUT34
Aug 31, 2007 12:34 PM
wicked2night
Dec 31, 2006 07:34 AM
