DPFI to MPFI swap-code4
Old May 24, 2007 | 08:02 AM
rustbucketrex's Avatar
Default DPFI to MPFI swap-code4
I have a '90 CRX DX that I did a MPFI swap on last weekend and I am getting a code 4 crank angle error code. I have a PM6 ecu, intake manifold, injectors, and a TD-18U distributor all from a single source (a '90 CRX Si that had been wrecked) and a wiring harness made for this swap. I have searched the archives before asking on here and most posts say to check my wiring. I have checked it many times and my C1, C2, B10 and B12 all test good from distributor to the ecu harness plug . I have checked my ground connections. I was not sure of the age of the donor distributor so I bought one from Distributor King(TD-02XP) and I am still getting a code 4. Can the PM6 ecu have a fault in it that would give this code?
Sorry for the long post but it is my first one and I don't want to get flamed for lack of imformation. My car, like several others in the archives won't run above 3K rpms.
Modified by rustbucketrex at 1:23 PM 5/24/2007
Old May 24, 2007 | 10:31 AM
Default Re: DPFI to MPFI swap-code4 (rustbucketrex)
Bump for an answer.
Old May 24, 2007 | 11:16 AM
jdm206's Avatar
im having the same problem as you.
Old May 24, 2007 | 11:18 AM
Default Re: DPFI to MPFI swap-code4 (jdm206)
Have you tried another ecu?
Old May 24, 2007 | 01:30 PM
Anybody?
Old May 24, 2007 | 02:02 PM
5iveLugEK's Avatar
why dont you try another ecu its not the dizzy obviously and if the wiring is right then thats not it either my next source would try and source a ECU.
This is what im doing because i was throwing a code 10 intake air temp and drove like that for a month and the car ran good and out of know where my car dies and i have no ground for #2,#3,#4 inj so i got another ecu
that would be my guess
Old May 24, 2007 | 02:15 PM
Default Re: (5iveLugEK)
I have another PM6 ecu coming tomorrow to try. I really wanted a PO8 ecu and a TD-42U distributor to be my next purchases for the D15B VTEC and Si transmission that I picked up to put in at a later date, but I knew I had to convert to MPFI anyway and I had everything for the swap(I thought so anyway).
Old May 25, 2007 | 12:12 PM
90sedan's Avatar
When i did my MPFI swap i first threw this code as well. Turned out it was my wiring at the ecu.
At spot b12 there was an existing wire, i had spliced into that instead of depinning and repinning the new wire. I fixed that, and the code went away.
Old May 26, 2007 | 02:01 PM
I finally fixed it. I will swallow my pride and admit my mistake in case anyone else does a search. While I was depinning the harrness plugs the tabs that make contact with the ecu pins were opened up to much. I depinned B10, B12, C1 and C2 to check them and then pushed the side pins in and tried just a single wire at a time on an ecu pin. I then bent the spring part back up and reinserted back in harness plug and reinstalled the white retainers. No more code 4
Old May 27, 2007 | 08:31 AM
EF_338's Avatar
tight man, maybe i need to do that cause i got that ecu and it didnt work at all
im now getting ground on the injectors but now i dont have spark?
JDMatt3
May 20, 2008 04:51 PM
rustbucketrex
Jun 28, 2007 06:43 AM
turbob18si
Dec 3, 2006 04:02 PM
extensioncordy
10
Oct 30, 2006 07:21 AM
WhiteDSM520
May 6, 2003 11:06 PM
