belts...
Old May 24, 2007 | 07:08 AM
rObBiErOb's Avatar
Default belts...
does anyone know how to change the power steering belt, AC belt, and alternator..? can't find any info on how to do it. i like to know step by step.... thanks... any info is good info..
Old May 24, 2007 | 07:23 AM
THC07's Avatar
Default Re: belts... (rObBiErOb)
go to auto zone and get the book.
you will always have somwhere to start, so long as you have a book
Old May 24, 2007 | 07:34 AM
Crazydave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rObBiErOb &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to change the power steering belt, AC belt, and alternator..? can't find any info on how to do it. i like to know step by step.... thanks... any info is good info..</TD></TR></TABLE>
Pay attention to which pulley each belt is on and how they are routed.
Loosen the tensioner bolt on the Power steering pump, and loosen the other bolts too. then move the pump, so that the belt comes off, install new belt, push pump a far as it will go, tighten tension bolt, tighten other bolts.
same AC & Alt
Old May 24, 2007 | 07:41 AM
rObBiErOb's Avatar
Default Re: belts... (Crazydave)
thanks for the info... do u know wheres a link i can click on for step by step...?
Old May 24, 2007 | 07:54 AM
Libertariat's Avatar
Ek Forever y0!
Haynes manual at your local autozone shouldn't be more than $20.
You'll rather have that than have to run inside and read some webpage.
Old May 24, 2007 | 08:05 AM
EE_Chris's Avatar
hondatech.info
Old May 24, 2007 | 08:36 AM
Crazydave's Avatar
Default Re: belts... (EE_Chris)
you can also go to :
http://www.redpepperracing.com
and click on service manuals.. hopefully one of your cars is there.
If not, they usually are similar... so still check them out.
Modified by Crazydave at 9:51 AM 5/24/2007
sneekz206
Jan 4, 2011 03:30 PM
HondaH22a#1
Jun 29, 2007 08:27 AM
Beau Gotti
Apr 24, 2006 06:10 PM
confucius
May 18, 2005 11:42 AM
TURBOED-TEG
Jun 19, 2003 09:09 PM
