belts...
belts...
does anyone know how to change the power steering belt, AC belt, and alternator..? can't find any info on how to do it. i like to know step by step.... thanks... any info is good info..
Re: belts... (rObBiErOb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rObBiErOb »</TD></TR><TR><TD CLASS="quote">does anyone know how to change the power steering belt, AC belt, and alternator..? can't find any info on how to do it. i like to know step by step.... thanks... any info is good info..</TD></TR></TABLE>
Pay attention to which pulley each belt is on and how they are routed.
Loosen the tensioner bolt on the Power steering pump, and loosen the other bolts too. then move the pump, so that the belt comes off, install new belt, push pump a far as it will go, tighten tension bolt, tighten other bolts.
same AC & Alt
same AC & Alt
Re: belts... (EE_Chris)
you can also go to :
http://www.redpepperracing.com
and click on service manuals.. hopefully one of your cars is there.
If not, they usually are similar... so still check them out.
Modified by Crazydave at 9:51 AM 5/24/2007
Beau Gotti
04-24-2006 06:10 PM
confucius
05-18-2005 11:42 AM
