what's a good header that clears ITR motor/trans brace?
Old May 23, 2007 | 09:36 PM
dubnine's Avatar
Default what's a good header that clears ITR motor/trans brace?
Right now i'm running a JDM DC header thats smashed, so its time for a new header. I really want a hytech/rage header, but considering the price of the header, i don't think i'll have enough to change my trans brace to a b16/GSR one. So what are my other options?
Old May 23, 2007 | 10:37 PM
itr1244's Avatar
Default Re: what's a good header that clears ITR motor/trans brace? (dubnine)
how is this itr related?
Old May 24, 2007 | 05:53 AM
R.Kelley's Avatar
itr's have an extra big brace that goes between the motor and tranny....all the others have a stamped sheet metal plate and lil bracket
but any who i've got a Vibrant J-spec(4-2-1)..its a knock off of the T1R...i dont have it on the car but it will clear.
Old May 24, 2007 | 05:55 AM
Padawan's Avatar
Darth ModerVader
The SMSP multi-piece 4-2-1 that we installed on my brother's car clears the brace.
Old May 24, 2007 | 06:13 AM
walker111's Avatar
Default Re: what's a good header that clears ITR motor/trans brace? (Padawan)
Toda clears the brace.
Old May 24, 2007 | 06:22 AM
94typeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">SMSP clears the brace. </TD></TR></TABLE>
maybe the 4-1 does, last time i checked the 4-2-1 doesnt
Old May 24, 2007 | 06:39 AM
Padawan's Avatar
Darth ModerVader
Default Re: what's a good header that clears ITR motor/trans brace? (94typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR &raquo;</TD></TR><TR><TD CLASS="quote">maybe the 4-1 does, last time i checked the 4-2-1 doesnt</TD></TR></TABLE>
The one we installed on my brother's car definitely does, and it's the 4-2-1 long-tube B18C5 header.
Old May 24, 2007 | 06:43 AM
94typeR's Avatar
no modifications done to anything? straight plug and play?
Old May 24, 2007 | 06:47 AM
Padawan's Avatar
Darth ModerVader
It was a bit of a while ago, but I believe there may have been one bolt head that was in the way slightly. Other than that, it just went right on with no modification to the brace, fan shrouds, AC or anything else.
If I'm not mistaken, the tubing configuration on Dave's early header designs may have required clearancing the brace, but I recall him stating that he eliminated that issue through a revised design.
Old May 24, 2007 | 06:58 AM
ZygSpeed's Avatar
Be careful in EXACTLY WHICH HEADER you're talking about, and to be positive ask Dave at SMSP when you order one.
My recent 4-2-1 (where they're all in the same plane unde the oil pan) doesn't make room for even a bolt head, much less ANY type of brace.
Old May 24, 2007 | 07:02 AM
dubnine's Avatar
Default Re: what's a good header that clears ITR motor/trans brace? (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">how is this itr related?
I hope u don't drive an ITR and don't know what's different on your motor then all other B-Series Engines.
Old May 24, 2007 | 07:07 AM
Padawan's Avatar
Darth ModerVader
Default Re: what's a good header that clears ITR motor/trans brace? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Be careful in EXACTLY WHICH HEADER you're talking about, and to be positive ask Dave at SMSP when you order one.
My recent 4-2-1 (where they're all in the same plane unde the oil pan) doesn't make room for even a bolt head, much less ANY type of brace.</TD></TR></TABLE>
Yes, you should certainly double-check with Dave.
Which header did you order?
Old May 24, 2007 | 07:37 AM
get RIGHT's Avatar
Default Re: what's a good header that clears ITR motor/trans brace? (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Toda clears the brace.</TD></TR></TABLE>
I can vouch.
Old May 24, 2007 | 08:19 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Which header did you order?</TD></TR></TABLE>
I described it above and its in your quote!
All I'm saying is that such blanket statements like yours are prone to not being "entirely" true!
Old May 24, 2007 | 08:22 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">I described it above and its in your quote!</TD></TR></TABLE>
David offers a number of 4-2-1 B-series headers that match your description, so I was simply curious which specific one you had ordered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">All I'm saying is that such blanket statements like yours are prone to not being "entirely" true! </TD></TR></TABLE>
You're right. I'll rephrase my original statement. It's true that not every SMSP header will provide the same amount of clearance.
Old May 24, 2007 | 08:32 AM
ZygSpeed's Avatar
Dave's a good friend of mine and has done a lot of work for/on my various ITRs.
All I was trying to point out is that "it all depends".
My particular one was his 4-2-1 1.9L version that's flat under the oil pan.
... I've got to get back to "work".
Old May 24, 2007 | 08:55 AM
Padawan's Avatar
Darth ModerVader
Agreed. My apologies if my original post was misleading.
401tuner
May 8, 2007 06:15 PM
mr. biggles
Sep 18, 2006 06:02 AM
tommymoose
Sep 10, 2005 12:31 PM
1BadCvC
Mar 9, 2005 02:33 PM
tilt
May 20, 2004 08:30 AM
