jdm gsr swap... TB and cable?
Old May 23, 2007 | 09:31 PM
beer30hatch's Avatar
Default jdm gsr swap... TB HELP
Just finished my B18C swap in my Teg and got everything hooked and running except for the throttle cable. The jdm TB linkage is obviously backwards and I cannot hook up the throttle cable to it. Can I turn the linkage right side up...use a usdm tB or....
BTW the motor is OBD1
Modified by beer30hatch at 10:47 PM 5/25/2007
Old May 24, 2007 | 05:06 AM
ziggz501's Avatar
Default Re: jdm gsr swap... TB and cable? (beer30hatch)
it seems like you should be able to use a usdm throttle body. just make sure you get the same size so you don't lose power. just compare the two side by side, and if the only difference is that the jdm one is backward then the usdm one should work fine.
Old May 24, 2007 | 05:19 AM
Big Bang's Avatar
Default Re: jdm gsr swap... TB and cable? (ziggz501)
I put a JDM GSR into a customers car. The bracket was identical to a USDM iirc.
Old May 25, 2007 | 09:35 PM
is there a difference between ls and gsr throttle bodies?
Old May 25, 2007 | 09:38 PM
Default Re: jdm gsr swap... TB and cable? (The Converted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Converted &raquo;</TD></TR><TR><TD CLASS="quote">I put a JDM GSR into a customers car. The bracket was identical to a USDM iirc.</TD></TR></TABLE>
I think youre right because my friends TB is exactly the same as mine but the linkage has 2 points to where the linkage can be attatched to and the one I got with the swap only has the wrong one
Old May 25, 2007 | 10:05 PM
RevOnRacerz's Avatar
i did a jdm swap in my teg too. what you gotta do is get a new throttle cable, i think type R worked for me, cuz its a little longer. the thing with jdm engines is they are from right hand drive cars so they route the throttle differently. but i rerouted mine close to the firewall, behind the intake manifold and connects to the throttle from over the throttle body.
Old May 25, 2007 | 11:52 PM
Default Re: (RevOnRacerz)
I think the one I have now is too long . I tried to do exactly what you did and I had alot of slack.
Old May 26, 2007 | 09:57 AM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beer30hatch &raquo;</TD></TR><TR><TD CLASS="quote">is there a difference between ls and gsr throttle bodies?</TD></TR></TABLE>
Only the pullies.
Old May 26, 2007 | 12:34 PM
Default Re: jdm gsr swap... TB and cable? (Dartanian)
ok thanks
M0N0C4M
Jan 16, 2012 08:46 AM
WGFletch4WS
May 30, 2007 07:43 PM
freakasis
Sep 4, 2005 01:02 PM
93Civic_hb
Apr 7, 2004 02:36 PM
1HotHonda
Aug 26, 2002 07:39 PM
