throttle cable
Old May 26, 2007 | 11:55 AM
WGFletch4WS's Avatar
Default throttle cable
i just swapped in a b18c (gsr motor) and kept the jdm intake mani on along wi tthe throttle body and the usdm throttle cable doenst work i tried using the usdm bracket but wont help since the butterfly "rotor" thing is different the cable ends up on teh wrong side...any ideas? what do i neeed
Old May 28, 2007 | 10:01 PM
beer30hatch's Avatar
Default Re: throttle cable (WGFletch4WS)
I just asked the same question and was told to use a usdm TB and run the cable along the firewall and over/under the intake. Also I had to use the bracket that came with the "jdm" TB that screws in next to the linkage.
Old May 29, 2007 | 04:01 AM
i just switched the spring and rotor thing on the tb and used the usdm bracket and worked great
Old May 29, 2007 | 02:49 PM
Default Re: (WGFletch4WS)
how were you able to take the linkage/rotor and spring to come off? I half-assly tried for like 5 min and decided to use my old TB. I didnt wanna do it but it was there and it worked.I would like to do it your way,can you tell me how?
Darren
Old May 30, 2007 | 10:19 AM
if u just unscrew the bolt it pops off with some force then just slide the new one on and tighten it
Old May 30, 2007 | 07:43 PM
thanks...will give it a shot
beer30hatch
May 26, 2007 12:34 PM
freakasis
Sep 4, 2005 01:02 PM
88 rex
Jul 18, 2005 05:36 PM
93Civic_hb
Apr 7, 2004 02:36 PM
whiteblurr
Jan 19, 2004 07:06 PM
