Larger Bore
Old May 23, 2007 | 09:11 PM
everyonesnaturalenemy's Avatar
Default Larger Bore
Is it possible to increase the bore of the B18C5? What sort of pros and cons would result?
Old May 23, 2007 | 09:27 PM
92TypeR's Avatar
FSAE
Default Re: Larger Bore (everyonesnaturalenemy)
Factory pistons are offered in .5 and 1mm oversized.
You will need to take the block to a machine shop and have them perform the proper boring operations and then hone.
Advantages - Increased dispalcement, more HP/TQ
Disadvantages - Cost
You can only go as far as 82mm on stock sleeves. You can always sleeve your block and run 85mm, as I did, which makes it a true 2.0L motor.
Old May 23, 2007 | 10:43 PM
itr1244's Avatar
pros: you gonna have fresh rebuilt motor,
cons: just making it larger bore won't give you too much gains. other mods are needed ==> money
Old May 24, 2007 | 01:01 AM
tONE.steR's Avatar
* B A N N E D *
Default Re: Larger Bore (itr1244)
82mm w/ 89mm stroke = 1880... aka 1.9L
I've seen them do over 210whp easy.
Old May 24, 2007 | 05:03 AM
GO-FIGHT-KILL's Avatar
92mm Crower crank, with 82mm bore.
92VXeg
Nov 21, 2008 10:28 AM
BigPlansNoMoney
Feb 24, 2008 08:01 AM
escape2me
10
Apr 25, 2004 08:20 PM
Quik Chris
Dec 21, 2002 10:11 AM
jpkl
Oct 15, 2001 06:26 AM
