B18C1 with CTR pistons trying to figure out compression ratio????
I have a B18C1 balanced and blueprinted bottomend with CTR pistons. Cylinder head is a B16A2 fully ported and polished with titanium valvesprings and retainers and CTR cams. Bolt ons are JG edlebrock intake manifold, Intake (jo blow) DC 4-1 Headers, high flow cat, and mandrel bent custom 2.50" piping. The ignition system is stock and it is running on a Hondata s100 with the OBD1 ECU and it has a 255lb walbro fuel pump, I'm not sure what the injectors are, I think they are stock Type-R. I have a Fuel meter and right now it sits at 48psi.
The car runs great no problems---- chirps the tires in 3rd gear with a GSR tranny (and yes it's dry pavement) I did a compression test and it ran about 250psi across all four cylinders. Is there any way some would be able to tell me what type of compression ratio I have. Thanks
Between 12.7 and 13.7 depending on who you talk to.
http://www.zealautowerks.com/
Will give you a rough estimate, but clearances should have been measured durring assembly.
No one can even begin to guess what has been done to this motor as far as milling/decking.
not to thread jack
but ive been doing a lot of researching on here
and im a lil concerned about my setup
i got the same setup as you...well im in the process of building it all i gotta do is assemble it anyways here what i got
b18c1 block
CTR pistons
stock b18c1 crank and rods
pr3 head with a resurface cause it was removed and i figured since its off i might as well get it resurfaced if it was warped in any way
top fuel stg 2 cams
stock valvetrain for now
spoon 2 layer headgasket
92 octane fuel too
am i looking at any clearance or drivability problems? its gonna be daily driven and tuned on crome too
b18c1 block
CTR pistons
top fuel stg 2 cams
92 octane fuel too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">so im good to go?</TD></TR></TABLE>
yep.
yep.
johnzm
566
Mar 19, 2013 05:13 AM
WhoDoYouThink
Oct 4, 2005 01:02 AM
