check engine light
Old May 23, 2007 | 06:28 PM
stock99si's Avatar
Default check engine light
hey guys, i was going to work and on my way back from work, my check engine light turned on in the middle of driving, im just wondering does anybody have any typica things taht go on civic si's 99 around 80 thousand miles? the car runs fine
2 days ago i did replace spark plugs.
Old May 23, 2007 | 06:31 PM
Kiwibird83's Avatar
Reigning GDD Queen
Default Re: check engine light (stock99si)
To many to mention, pull the codes and post them for us and then we can help you.
Old May 23, 2007 | 06:34 PM
stock99si's Avatar
Default Re: check engine light (Kiwibird83)
is there anyway i coudl check its o2 sensor, cuz i think that might be it?
Old May 23, 2007 | 06:41 PM
stock99si's Avatar
bump?
Old May 23, 2007 | 06:48 PM
stock99si's Avatar
please someone i know u know hondaers
Old May 23, 2007 | 06:52 PM
97Ej6mike's Avatar
https://honda-tech.com/zerothread/1901557
Can check the code yourself, and tell us what code it is, and you shall recieve lots of help.
Old May 23, 2007 | 07:02 PM
stock99si's Avatar
Default Re: (97Ej6mike)
what do they mean by loop a thin wire to both holes of connector?
Old May 23, 2007 | 07:07 PM
97Ej6mike's Avatar
You just put a wire or paperclip in the two holes, like it says, bridging the gap, connecting them.
Turn your car to 2nd accessory, and do as follows by counting the blinks
Long blinks are 10's
short and fast are singles.
For example, if your throwing say a code 41 (o2 sens i think, just as an example)
it would go like this
1.) 2nd accessory is engaged, all the lights will come on as normal, like when it is all the time. After that, then your CEL sequence will begin
say its code 41
It would be like
____ ____ ____ ____ _
4 long blinks, and 1 short one = code 41.
Old May 23, 2007 | 07:08 PM
mr_nemesis2003's Avatar
get a paper clip and stick one end of it to one side of the connecter, and the other end to the other side. Do this and count the number of times it blinks. Long = +10, and short = 1. There might be multiple codes
Old May 23, 2007 | 07:12 PM
stock99si's Avatar
Default Re: (mr_nemesis2003)
ahh icic okay i get that part, anybody got pic of location of connector?
Old May 23, 2007 | 07:16 PM
zerovandez's Avatar
Old May 23, 2007 | 07:18 PM
stock99si's Avatar
Default Re: (zerovandez)
okay well its dark outside and i dont have garage, so ill let u guys know tmrw, is it safe to drive the car considering its running fine?
Old May 23, 2007 | 07:44 PM
stock99si's Avatar
Default Re: (stock99si)
nump
Old May 23, 2007 | 07:46 PM
94c1v1cex's Avatar
yep just don't rag on it
Old May 23, 2007 | 08:16 PM
stock99si's Avatar
Default Re: (94c1v1cex)
ohh icic, wtf does the o2 sensor do? can i just pull o2 plug and restart it?
Old May 24, 2007 | 02:50 PM
stock99si's Avatar
okay i did test and it did 4 qu9ick blinks which means second 02 sensor, what do i do now, is there anyway of avoiding replacement? am i losing power?
Old May 24, 2007 | 03:53 PM
stock99si's Avatar
BUYMP
Old May 24, 2007 | 04:03 PM
h2392si's Avatar
Your running in limp mode if your CEL is on. If its the O2 sensor you gotta change it. Its messing up your milage and you wont be able to hit VTEC. When i was low on funds once and had to replace mine, I took it out and cleaned it really well with carb or break cleaner? Can't remember. Search because there are threads on how to do this. Just a quick fix. The best thing to do is replace the correct 02 sensor. Good luck.
Old May 24, 2007 | 04:04 PM
9200RPM's Avatar
go to autozone (or what ever parts store you have) and have the run a scan on it...they can tell you what it is for free...My guess is an o2 sensor
Old May 24, 2007 | 04:06 PM
9200RPM's Avatar
Default Re: check engine light (TurboB16aEG)
Thats what i get for not reading the whole post...When you get a new sensor get a universal o2 sensor it will save you a lot of money...all you do is cut the plug off the old and put it on the new one...
Old May 24, 2007 | 05:18 PM
pdiggitydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si &raquo;</TD></TR><TR><TD CLASS="quote">Your running in limp mode if your CEL is on. If its the O2 sensor you gotta change it. Its messing up your milage and you wont be able to hit VTEC.</TD></TR></TABLE>
This is not true for all CEL's - not all throw the car into "limp" mode
edit***
You said 4 short blinks? That isnt 2ndary o2....
4 CKP - crank position sensor
Old May 24, 2007 | 05:26 PM
cimo463's Avatar
Default Re: (pdiggitydogg)
Bosch = Junk
Old May 24, 2007 | 05:44 PM
9200RPM's Avatar
Default Re: (cimo463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cimo463 &raquo;</TD></TR><TR><TD CLASS="quote">Bosch = Junk </TD></TR></TABLE>
I don't think his application is requiring anything more, and it will save him money. I have personally ran bosch o2's and had no problems, as well as a bosh wideband sensor on my wrx with no problem.
Old May 24, 2007 | 07:20 PM
stock99si's Avatar
Default Re: (TurboB16aEG)
iight ill try cleaning it
Old May 24, 2007 | 08:18 PM
EM1SiR85's Avatar
From: everywhere., cali,nevada,new york., united states
what code is it?
