Aftermarket calipers
Old May 23, 2007 | 05:47 PM
jdm4drSi's Avatar
Banned
Default Aftermarket calipers
Anyone know if there are any performance companies manufacturing calipers? Front and back? I know Wilwood has a kit for cheap @ $600.00 but I think the 12" rotor upgrade is a bit of an overkill for the EF's.
Anyone know if you can mod DA calipers to the EX spindles... say the Spoon ones?
Old May 23, 2007 | 07:19 PM
dr_latino999's Avatar
Default Re: Aftermarket calipers (jdm4drSi)
DA Calipers bolt up no problem to EX knuckles.
Old May 23, 2007 | 07:26 PM
redzcstandardhatch's Avatar
something different
Default Re: Aftermarket calipers (dr_latino999)
spoon calipers are an assload of money
with bigger spindles (ex/sir/DA), you've got a huge amount of options...ITR stuff, NSX, and all the aftermarkets that fit that stuff
Old May 23, 2007 | 08:05 PM
user 72830283's Avatar
Yep..there's a write-up midst the FAQ's about the EX Knuckles. But a cheaper route might be to upgrade your brake/hydraulic fluid delivery to the calipers itself. Simple upgrades such as a larger MC:BB combination along with newer/steel braided lines will produce a major improvement over the stock setup. The above is also suggested if you're looking to upgrade to big-brake setups to accomodate the higher/faster demand for brake fluid.
p.s. you'll be surprised what the DA MC:BB combination+better brake lines will do for braking!
Old May 24, 2007 | 01:31 PM
jdm4drSi's Avatar
Banned
Ya, I'm having the complete braking system re-done as this car has never had decent braking since I've owned it. Probably since the poor thing got outta the Honda assy line.
SS lines, calipers, big brakes(front), all that stuff is being considered, and of course, the 15/16 EX MC! OEM too. Booster, the whole nine, just want to see what are my options for calipers using the EX spindle assy.
Ya, spoons cost a decent paint job, so I might be opting for the Dynalite Wilwoods... they're not bad in pricing for a 4 piston design... anyone used them?
Old May 24, 2007 | 02:07 PM
89efDUSTY's Avatar
https://honda-tech.com/zerothread?id=1811368 aftermarket could be as good as OEM, maybe better, but sometimes even worse. Read this and you probably will never have another brake question...I mean come on the OP's name is Brakeexpert that write up is awesome gl
Old May 24, 2007 | 02:38 PM
jdm4drSi's Avatar
Banned
Default Re: Aftermarket calipers (89efDUSTY)
I will definetly read up on that thing.... thanks dude!
Old May 24, 2007 | 03:57 PM
89efDUSTY's Avatar
Not a problem...there is another write up thats pretty good. If i find it i will PM and post
Old May 24, 2007 | 10:33 PM
jdm4drSi's Avatar
Banned
Is it the thread about staying away from drilled rotors? Waaaaaaay ahead of you.
That article on the brake setup was pretty cool, I'm rethinking my brake plans for my ride...
BombSquad91
Apr 18, 2014 11:46 AM
BrakeExpert
14
Jun 16, 2008 09:40 AM
Rainman15
Jan 4, 2005 01:42 PM
virginia_dude
Feb 17, 2004 04:21 PM
RiceRocket16
Jan 31, 2003 07:34 AM
