What bolts do i use for sway bar brackets?
Old May 23, 2007 | 04:12 PM
truevietluv636's Avatar
Default What bolts do i use for sway bar brackets?
I need some bolts to mount the front and rear sway bars. Also, i looked at the rear brackets and the car and noticed the car isnt threaded for the bolt, how do i bolt the brackets and d brackets on the car? Do i need to use nuts? What size bolts do i use, i've brought some grade 8 5/16 bolts and they didnt fit the brackets.
Old May 23, 2007 | 04:35 PM
Default Re: What bolts do i use for sway bar brackets? (truevietluv636)
This is what i got....
Old May 23, 2007 | 05:45 PM
EK9Rider's Avatar
what are you referring too about treaded holes - post pics of the underbody of your car - what kind of car do you have
Old May 23, 2007 | 05:49 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: What bolts do i use for sway bar brackets? (EK9Rider)
just go to a junkyard and get them from the same location. They're 12mm head suspension grade bolts. They have a 10mm shaft. Thread is 1.25 or 1.5 i cant remember.
Old May 23, 2007 | 07:16 PM
Default Re: What bolts do i use for sway bar brackets? (B serious)
sorry about my bad description. i got a 92 civic hatch vx
here's the pic, soo i just need the 12mm bolt with 10mm shaft and i just bolt those down in the holes? or would i need a nut to go on the other side of the bolt.
Old May 23, 2007 | 07:18 PM
sniggler316's Avatar
You need a nut on the back side
Old May 23, 2007 | 07:23 PM
Default Re: What bolts do i use for sway bar brackets? (sniggler316)
thats the answer i was looking for. thanks.
anyways, you guys know where i could get a grade 8 bolt for those? i went to home depot and osh. Home depot doesnt even carry those and osh only has standard sizes. no junk yards around here...
Old May 23, 2007 | 08:03 PM
BBY98EX's Avatar
autozone has 3/8-16 (grade 8) bolts,nuts,washers,and lock washers . they are behind the counter so you will have to ask for them
Old May 23, 2007 | 08:06 PM
Default Re: What bolts do i use for sway bar brackets? (BBY98EX)
good ****. thanks.
Old May 24, 2007 | 04:12 PM
just got screwed... where do i get the front end links? cant seem to find them anywhere...
Old May 24, 2007 | 04:29 PM
i found a part number.... but not sure if its correct because no picture. 51320-ST7-003
Old May 25, 2007 | 08:13 AM
this is all i found on ebay (which wont work)....
Modified by truevietluv636 at 7:58 PM 5/25/2007
Old May 25, 2007 | 08:49 AM
IN VTEC's Avatar
That swaybar looks like it'll need GS-R/ITR front swaybar endlinks. The LS/Civic Si ones won't work.
Old May 25, 2007 | 09:03 AM
philosofy1's Avatar
the endlinks you need for the front are off of a itr.
the part number is:
51320-st7-003
Old May 25, 2007 | 06:07 PM
Default Re: What bolts do i use for sway bar brackets? (philosofy1)
thanks guys.
Old May 27, 2007 | 01:06 AM
cant find the gsr/itr endlinks for cheap.... anyone got some i could buy off???? paypal or meet up in bay area.
96Formula6spd
Jun 9, 2011 05:13 PM
HotCheetos
10
Dec 11, 2010 09:07 PM
HKSuperSi
Feb 13, 2007 08:38 PM
BolivianDc2
Sep 28, 2003 07:03 PM
RevedOut
Feb 12, 2002 01:36 PM
