h22 w/ h23 trans
Old May 23, 2007 | 04:09 PM
pray2dalude's Avatar
Default h22 w/ h23 trans
im about to work on my prelude and i have a friend that wants just the engine w/o transmision. and i was wonderin if i buy a h22 block and build my h22 with build internals would i be able to use my h23 trans
Old May 23, 2007 | 04:12 PM
AndrePerras's Avatar
Default Re: h22 w/ h23 trans (pray2dalude)
yes but the gears are slightly longer than an H22.
Old May 23, 2007 | 04:20 PM
so would i be able to fix that? or would it be too much work
Old May 23, 2007 | 04:58 PM
md23vtec's Avatar
Default Re: (pray2dalude)
Really isnt anything to "fix" so to say. It works give it a try you might like it. If you want the shorter gears then get a h22 tranny.
Old May 24, 2007 | 04:44 AM
when you say the gears are longer do you mean that the gear ratios are longer or what.
Old May 24, 2007 | 05:07 AM
Lewdin' Incognito's Avatar
Yeah, acceleration will be slightly lower but you'll also have slightly higher top speed and better highway mpg.
92civlude
Jun 1, 2009 01:16 PM
pkolaboy
Mar 26, 2008 02:27 PM
force-fed
Jan 31, 2006 08:50 PM
nitroeg
Aug 31, 2005 09:58 AM
tintin11
Sep 11, 2003 08:41 PM
