Drive plate bolt(s) removal
Old May 23, 2007 | 03:30 PM
saikou's Avatar
Default Drive plate bolt(s) removal
I recently got a H23 long block from hmotorsonline which was out of a Prelude w/ an automatic transmission. I have removed the torque converter assembly and am in process of removing the drive plate. Is there a special socket I need to remove the 8 bolts holding it onto the crank? I know I will need to remove them in a crisscross pattern.
And are these the same bolts that bolt the flywheel onto the crank for my clutch?
Thanks.
Old May 23, 2007 | 03:32 PM
117's Avatar
117
They're regular 12 point 17mm bolt heads. You cannot use AT flexplate bolts for a manual tranny flywheel. The AT bolts will be too short.
Old May 23, 2007 | 03:34 PM
saikou's Avatar
Default Re: (117)
Thanks a ton.
angrysmileyface
Sep 14, 2014 05:09 AM
lsvtec101
Transmission & Drivetrain
Mar 6, 2009 09:23 PM
vaypourus
Nov 9, 2006 06:26 PM
LsTurbo91
Jul 21, 2005 05:41 PM
88_T-Rex
Jul 11, 2005 10:20 PM
