How to get rid of VSS check engine code on a 91 DA???
Old May 23, 2007 | 02:47 PM
DA_JDM's Avatar
Default How to get rid of VSS check engine code on a 91 DA???
Can anyone help out on that issue...im converted to obd1...and my ecu is not able to detect the VSS because i have the speedometer cable instead of the VSS...
Thanks
Old May 24, 2007 | 06:53 AM
DA_JDM's Avatar
Default Re: How to get rid of VSS check engine code on a 91 DA??? (DA_JDM)
Old May 24, 2007 | 02:35 PM
DA_JDM's Avatar
nobody
Old May 24, 2007 | 05:18 PM
turbo93da's Avatar
you need to ensure that the speed cable is in and then check your jumper for the wire for the speed sensor from the gauge ensure that that wire is properly installed on the jumper
slow-ef
Nov 5, 2008 07:27 AM
EF9 JAMS!!!
Dec 10, 2006 10:26 AM
aaronhume
Nov 21, 2006 12:00 PM
Sic_DA_Nine
Jul 21, 2006 06:46 PM
TMaccord91
Oct 6, 2004 09:30 PM
