Blown headgasket. Where do I go from here?
Old May 23, 2007 | 02:37 PM
turboeg831's Avatar
Default Blown headgasket. Where do I go from here?
I want to replace the headgasket myself. What's the process, and what parts do I need? This is for a d16y7 btw...
Old May 23, 2007 | 03:20 PM
turboeg831's Avatar
bump
Old May 23, 2007 | 03:28 PM
deadline's Avatar
go to local auto store and buy a service manual for your car...
Old May 23, 2007 | 05:04 PM
turboeg831's Avatar
Planning to fix it myself. Can anyone give me some pointers? Where do I start? Is there a DIY tutorial anywhere?
Old May 23, 2007 | 05:06 PM
Padawan's Avatar
Darth ModerVader
Default Re: (turboeg831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboeg831 &raquo;</TD></TR><TR><TD CLASS="quote">Planning to fix it myself. Can anyone give me some pointers? Where do I start? Is there a DIY tutorial anywhere?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">go to local auto store and buy a service manual for your car... </TD></TR></TABLE>
Old May 23, 2007 | 05:11 PM
_skitzo_'s Avatar
Default Re: Blown headgasket. Where do I go from here? (turboeg831)
http://www.haynes.com/na.html
Best bang for your buck!
Old May 23, 2007 | 05:45 PM
Kiwibird83's Avatar
Reigning GDD Queen
Remove valve cover+timing cover, remove belt, remove head, replace gasket, install is reverse of removal.
Seriously its fairly straighforward, the smaller details that you need will be outlined in a service manual, along with the torque specs for the head, so just spend the 10 dollars and make your life much easier.
Old May 23, 2007 | 06:30 PM
95dsol's Avatar
Bump
Old May 23, 2007 | 06:31 PM
97Ej6mike's Avatar
Its pretty straight forward, get a service manuel for your car, they will show you (in pictures) step by step of how to do it. Haynes is a good choice of a manuel. Any autostore will carry ones for most cars, civics are popular, you shouldnt have trouble fiding one.
Old May 23, 2007 | 06:35 PM
EG2Driver's Avatar
Default Re: (97Ej6mike)
there is a tightening and un-tightening sequence you must follow.
Old May 23, 2007 | 07:05 PM
chingpo05's Avatar
Default Re: (DeadEnd9009)
if it over heated then go ahead and get your head machined while you are at it
Old May 23, 2007 | 07:06 PM
H22Apowered's Avatar
like others have said get a repair manual . it is probably one of the most important things you will buy for your car especially if you want to do most of the repairs your self another thing you may want to consider for your current project is taking the head to a machine shop to get it checked for warpage and cracks also if you have the funds to do it you may just want to get the head re worked it can save you the cost and headache of having to remove the head again in the near future but if your a little strapped for cash at least get the head checked otherwise you may find that after putting your new head gasket on you have the same problems as you did before.
Timtation
Honda S2000
Mar 24, 2008 09:33 AM
bulit184
Honda Civic (2001 - 2005)
14
Nov 13, 2007 12:21 AM
keviiinnnnn
Oct 16, 2007 08:48 AM
95civiccpdx
Aug 15, 2007 01:58 PM
TIRENECK
Jan 15, 2004 01:09 PM
