RC Injectors what is the difference? Help Needed
Old May 23, 2007 | 01:50 PM
BoRiCuA's Avatar
Default RC Injectors what is the difference? Help Needed
RC Injectors what is the difference between SL4 SL9 and SL10?
Old May 23, 2007 | 03:10 PM
BoRiCuA's Avatar
Default Re: RC Injectors what is the difference? Help Needed (BoRiCuA)
Someone has to know.....
Old May 23, 2007 | 03:55 PM
9200RPM's Avatar
From when I'm reading, its has to do with the circumference of the injector...
Old May 24, 2007 | 03:42 AM
BoRiCuA's Avatar
Default Re: RC Injectors what is the difference? Help Needed (TurboB16aEG)
Just to clear things up, i spoke with the guys over at RC ENG. he basically told me that SL4 can be used just about with any car with machining done(almost like made to fit, like what you said circumference)
And that the SL9 is for honda /acura. He said order for your application if you want a direct fit.
clu
May 14, 2003 12:27 AM
SpeedMonkeyRacing
Apr 25, 2002 10:15 AM
