where's my traction?!
Old May 23, 2007 | 11:56 AM
94c1v1cex's Avatar
Default where's my traction?!
i took the project ej1 to a track today for some fun with some other guys from my classes. it has tokico shocks dropzone coilovers and front and rear strut tower bars, and a rear camber kit... brand new kumho ecsta ast tires
as i went around a pretty wide turn the car just started to go sideways... wdf? any suggestions? i was going about 45 through the turn
i don't think it should've slid out from under me that easily
Old May 23, 2007 | 12:05 PM
instructor74's Avatar
Default Re: where's my traction?! (94c1v1cex)
what are your settings, ride height, toe, camber, any formal driving classes. Are you running a rear sway bar. You said brand new tires. most tires have a brake in period before they reach max grip. Your question is so wide open it is impossible to answer.
Old May 23, 2007 | 12:08 PM
94c1v1cex's Avatar
Default Re: where's my traction?! (instructor74)
it's dropped 2 inches, and the camber is just a little bit negative, toe is right. There's no rear sway bar. never had a formal driving class but i've had i guess you could say lessons with a track driver
Old May 23, 2007 | 12:38 PM
94c1v1cex's Avatar
bump
Old May 23, 2007 | 12:48 PM
let me phrase it this way. someone could give you a perfectly set up car and you could get in it and spin it on a corner at 45 that they drove through at 100 because of driving ability. You are going to need to get someone that knows how to set up/drive a car with you to find areas that need improvement or you might want to get involved with a chapter of the scca in your area. Many offer driving classes and there are a ton of people that you will meet that will be able to help you sort out your car for running at the track.
Old May 23, 2007 | 02:46 PM
94c1v1cex's Avatar
alright man thanks i'll look into that
Mr_ET
Suspension & Brakes
Nov 8, 2009 07:24 PM
Tarmac Junkie
10
Jul 31, 2008 05:02 PM
kefka
Mar 6, 2003 08:26 PM
acaraintegara
Nov 3, 2002 08:18 PM
ITRmike98
24
Jul 31, 2002 04:00 PM
