Removing leftover A/C items in EG help...
Old May 23, 2007 | 10:29 AM
Ep1dem1c's Avatar
Default Removing leftover A/C items in EG help...
I am in the middle of a wire tuck. I am putting my fuse box wire through the hole below. How do i remove the metal piece that was used for the A/C. Any pics of this being uninstalled from the inside? thanks
Old May 23, 2007 | 10:37 AM
FalkenSiR's Avatar
Default Re: Removing leftover A/C items in EG help... (Ep1dem1c)
whats on the other side? remove that
Old May 23, 2007 | 11:01 AM
De_tour's Avatar
Modified by De_tour at 9:48 PM 5/28/2007
Old May 23, 2007 | 12:18 PM
94hatchling's Avatar
also, once you pull the evaporator, that hole will be open. i know there are a few different places on the interweb that sell an A/C block off plate or plug. just an FYI.
for example...
http://www.jhpusa.com/catalog/...d=995
Old May 23, 2007 | 12:40 PM
De_tour's Avatar
Default Re: (94hatchling)
Old May 23, 2007 | 04:41 PM
De_tour's Avatar
Default Re: (De_tour)
bump
Old May 23, 2007 | 05:12 PM
hatchi's Avatar
you dont need to take out the dash to take off that box. you will need a long extension and 10 mm bolts and it will slide out. However you will need to take off the glove box
Old May 23, 2007 | 05:18 PM
De_tour's Avatar
Default Re: Removing leftover A/C items in EG help... (hatchi)
TheGearHead
Mar 19, 2014 07:33 PM
s1ngle
17
Feb 19, 2007 04:05 PM
JeBuSrIcE
12
Feb 8, 2006 04:26 PM
civicsareslow
Jan 11, 2006 01:06 PM
revolt_allmotor
Jul 21, 2005 09:12 AM
