BDL/STR fuel rail fitting
Old May 23, 2007 | 09:58 AM
HpRevolution's Avatar
Default BDL/STR fuel rail fitting
Does anyone know where i can get the nut/fitting that holds the fuel banjo onto the fuel rail? I misplaced mines and can't start the car because fuel leaks out if i use a standard nut to hold it into place.
Old Jun 5, 2007 | 02:52 PM
hatchysi's Avatar
Default Re: BDL/STR fuel rail fitting (****revolution)
are you talking about the acorn nut on the fuel fitting that connects to the line? oh im carlos from bdl industries by the way you could get that part from us just call your local distributor or not sure where you are located but you can call NOPi or options auto salon or hybrid performance here's the part number BDLFK-100 we sell it as a kit so it will come w/ a new fitting w/ the crush washers and acorn nut 4 injector o rings and the -8 plug for the other end of the fuel rail.
johnwohl
Feb 10, 2008 11:07 AM
HpRevolution
May 23, 2007 09:42 AM
sohc1200cc
Nov 3, 2006 10:02 AM
elmalouno
Jul 4, 2005 06:35 AM
drift2004
Apr 19, 2005 12:54 PM
