obd1 pr4: what fuel map to use
$cat /dev/urandom
I have a obd1 pr4 that I am going to use to run a b18b in a crx si. I have crome, but I don't know what rom to use on this setup. The p72 makes sense because its for the b-series, but i dont need vtec control at all at this point. the other options are p30, and p28, both of which i think are less relevant to the setup than the p72.
the other issue is: will the p72 rom run on the pr4? i believe they are in the same family according to the old pgmfi wiki.
Basically what i want is to run the stock obd1 pr4 map, but add launch control, and adjustability to be messed with later, using crome and a wideband.
$cat /dev/urandom
I talked to xenocron and he sent me a p30 rom to use. I am in the process of figuring out what he did to it, but it doesnt even have an option to turn on vtec, which is good for me because i wasnt looking for vtec features at this point.
also, i managed to salvage a page from the PGMFI Wiki about getting the Crome extra features found on http://sourceforge.net/projects/pgmfi/ to work in Crome. here it is .. http://mycomputerninja.com/~jo....html
