97 integra b20...it's bogging hard
I just did a swap on a 97 b20 integra....it bogs hella hard...i converted to obd1 with an jumper harness and p75. It idles fine no check engine lights..it's hella slow. like when i gas it it barely revs up..it picks up real slow and then around 4.5k it starts to kinda pull but i can barely make it up a driveway without waiting for it to rev up. I got ngk iridiums in there..im not sure if thats an overkill... PLEASE help..this is my daily driver and my ls took a crap on me and a b20 swap was the only thing i could afford..any help would be great..
timing is good and distributor is good..i kinda fixed the problem...it only bogs when i WOT..still no check engine codes..when i drive it normally its fine but when i do more than about 1/4 throttle..the motor starts to choke and bog but when im lightly on the throttle it goes to redline with no problem..please help me
i finally fixed that ****..it was the distributor...i didnt know that the gsr one would make it run like that...poped in a LS one and it was fine..thanks for all the help
16
Feb 2, 2013 02:28 PM
B16acivicsedan91
Nov 19, 2009 11:39 AM
Oacosta27
Dec 7, 2006 12:48 PM
