Transmission Problem
Old May 23, 2007 | 08:01 AM
Chillinit's Avatar
Default Transmission Problem
I have a Type R trans that is giving me some issues. Its is very notchy when going into gear and will not go in gear at high rpms. Also, the notchy-ness gets worse as it heats up. I'm thinking the cause is my sycros but I'd like some feedback to be sure. Anyone have any ideas?
Old May 23, 2007 | 01:01 PM
Chillinit's Avatar
Default Re: Transmission Problem (Chillinit)
has anyone had similar issues?
Old May 23, 2007 | 02:01 PM
oneprelude's Avatar
when does it occur? In the morning? Or after you have driven for a while?
Old May 23, 2007 | 06:15 PM
Chillinit's Avatar
Default Re: Transmission Problem (oneprelude)
notchy in the morning, and progresively gets more notchy as it heats up. Will not go into gear at high rpm regardless of temperature.
Old May 23, 2007 | 06:47 PM
4g hatch's Avatar
im not being a smartass but do you have oil in it and what kind are you running.
Old May 24, 2007 | 03:18 AM
Chillinit's Avatar
Default Re: (4g hatch)
I changed the oil recently to see if that would help, however the problem persists. I also bled the system and that didn't help.
I'm running stock honda manual transmission fluid.
Old May 24, 2007 | 05:49 PM
Chillinit's Avatar
Default Re: (Chillinit)
any one experience this problem?
Old May 24, 2007 | 05:53 PM
4g hatch's Avatar
is there any grinding.
Old May 25, 2007 | 03:39 AM
Chillinit's Avatar
negative, no grinding.
Old May 26, 2007 | 08:03 AM
Chillinit's Avatar
up
DJ4Jesus77
Honda Civic (2001 - 2005)
10
Oct 8, 2010 08:57 PM
01-0720
Honda Motorcycles
16
Oct 3, 2006 09:01 PM
tnord
26
Oct 14, 2005 07:55 PM
00itr
Oct 21, 2003 04:03 PM
rubens
Jul 14, 2003 11:33 AM
