head gasket
Old May 23, 2007 | 06:35 AM
iNCREDiBLYSLOW's Avatar
Default oil leak
96 accord 4 cyl 2.2 automatic
about 3 monts ago i had oil leaking into my spark plugs, for the second time. i took it to the shop and they cleaned it all out and "fixed" it. now 6,000 miles later its leaking oil in the spark plugs again. what could be the cause?
Modified by iNCREDiBLYSLOW at 8:01 AM 5/23/2007
Old May 23, 2007 | 07:51 AM
Eddiebx's Avatar
there are orings under the cam caps in the spark plug tube as well, this requires removing ur cam caps to access. and these are prone to leaking as well as the orings under the valve cover. it sounds liek the mechanic replaced the orings under the valve cover instead of the orings under the cam caps.
patrickstar
19
Feb 16, 2010 06:48 AM
boostedegls
Aug 5, 2009 11:15 PM
atarigamer01
12
Oct 17, 2007 12:42 PM
SuicideSlide
Feb 14, 2007 04:53 AM
peAches yO
Oct 23, 2005 06:17 PM
