proper way to adjust clutch pedal?
Old May 23, 2007 | 05:40 AM
mikeycivic's Avatar
Default proper way to adjust clutch pedal?
I have a 00 em1 that I just put a clutch in. The clutch is great but it wont go in gear unless the pedal is about an inch off the floor. How do I properly fix this?
Old May 23, 2007 | 05:42 AM
92ehatch's Avatar
Default Re: proper way to adjust clutch pedal? (mikeycivic)
you can adjust the clutch by turning the plunger/rod that attaches ot the pedal.
go under the dash.
find the clutch
find the rod attached to the pedal
loosen lock nut
turn the rod (not sure which direction raises/lowers engagement mabey someone else will chime in with that answer,or just test it and find out)
tighten lock nut
test.
Old May 23, 2007 | 05:43 AM
mikeycivic's Avatar
Default Re: proper way to adjust clutch pedal? (92ehatch)
Old May 23, 2007 | 02:34 PM
mikeycivic's Avatar
Corksil
Oct 31, 2011 03:59 PM
redman223
Jul 13, 2007 07:19 PM
team 15
Jun 8, 2007 04:23 PM
tristantiojanco
Apr 2, 2007 03:43 PM
acmeotally
Jul 29, 2005 09:32 AM
