OBD1 H22 DISTRIBUTOR WIRING
WELL ANYONE HERE KNOW HOW TO WIRE UP A OBD1 H22 DISTRIBUTOR TO A CIVIC DX HATCH I WOULD APPRECIATE IT THIS WILL HELP COMPLETE MY BUILD........THANX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">what do u mean that does not cover it??? its all in there.</TD></TR></TABLE>
+1 That's what I used to wire mine up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chem Geek »</TD></TR><TR><TD CLASS="quote">
green = TDC.,,,
if you have an external ignition coil, there is a green wire that connects the coil to the dizzy as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
99 civic ex distributor wires (labels & colors):
TDC (top dead center) - ORN/BLU(dizzy color) or GRN(egnine harness color)
TDCM (ground) - WHT/BLU(dizzy color) or RED(egnine harness color)
CKP (crankshaft position) - LT BLUE or BLUE/GRN(dizzy colors) or BLU(engine harness color)
CKPM (ground) - LT BLUE/YEL or WHT(dizzy colors) or WHT(engine harness color)
CYP (cylinder position) - ORN(dizzy color) or YEL(engine harness color)
CYPM (ground) - WHT or BLK(dizzy colors) or BLK(engine harness color)
ICM (ignition control module) - YEL/GRN
Power wire - BLK/YEL
Tachometer - BLU
2000 prelude distributor, ext coil, and CKP/TDC sensor wires (labels & colors)
here is also the ecu locations for obd2 for each of these wires.
4 wires go to CKP/TDC sensor ontop of the crankshaft:
C3 - TDC - GRN
C13 - TDCM - RED
C2 - CKP - BLU
C12 - CKPM - WHT
distributor:
C4 - CYP - YEL
C14 - CYPM - BLK
A20 - ICM - YEL/GRN
tachometer - BLU(should be on 2 prong plug)
EXTERNAL IGNITION COIL will have 3 wires coming out of it. 2 connect to the distributor and 1 goes to a power source.:
GRN@coil, GRN@dizzy - connects coil to dizzy
YEL@coil, BLK/YEL@dizzy- connects coil to dizzy (should be a LARGE wire)
BLK/YEL - connects coil to power source.
Modified by hondaZvic at 12:45 AM 9/18/2007
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">
Tachometer - BLU
C3 - TDC - GRN
C13 - TDCM - RED
C2 - CKP - BLU
C12 - CKPM - WHT
distributor:
C4 - CYP - YEL
C14 - CYPM - BLK
A20 - ICM - YEL/GRN
h22turbodelsol
Dec 7, 2003 12:30 AM
