integra sedans... antenna?
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
okay, i have a 99GSR sedan and i have no antenna. i'm assuming the antenna is in the rear glass or whatever (someone told me this, tell me if im wrong). but i saw an LS sedan the other day with an antenna in the same spot as a normal coupe (rear left).
so which sedans have antennas and which don't? just curious.
98 + have no attenna. Its built into the glass. As a matter of fact it may even be 96+. because 96 was the first year honda built antenna's into the glass
that's correct. the orange wires in the top half of the rear window is for the radio antennae. in the area above the right rear seat of the bench there is a little bulge where the headliner meets the glass. that's where the antenna meets the antenna lead and goes all the way to your head unit.
is there a way to add this antenna to my older model sedan?
[QUOTE]Yes you can. Replace the entire rear windshield and shave your stock antenna QUOTE]
Wouldn't work anyway . . .
i double checked my helms manual and it does show the antenna lead going from that portion of the headliner down the right C-pillar to the floor and to the radio from there. i'll have to look a lil more carefully to see how the defroster connections are...
Does the manual show it on the side or top of the glass. It is very uncommon for solder locations to be anywhere other than the sides of the glass due to soldering being one of the more difficult processes on glass.
phateless
Jan 22, 2003 09:02 AM
