K24a1/K20a2 head oil orifice blocking question?
Old May 22, 2007 | 04:17 PM
Hellblazer420's Avatar
Default K24a1/K20a2 head oil orifice blocking question?
OK im workin on my k24 right now and i was told to remove the little restrictor orifice (part #11135-PNA-000) that normally lubricates the twin countershaft oil pump. I removed it and noticed the thread pitch is so different than anything i have seen. I looks to be JIC or NPT threading and i have no clue what bolt i should use to block the passage. What have you others done for this? What bolt did you use? Or what is the thread pitch? Any help would be great im trying to finish the car and get it back on the road soon.
Old May 23, 2007 | 06:22 AM
Nikos's Avatar
Default Re: K24a1/K20a2 head oil orifice blocking question? (Hellblazer420)
This is the oil jet that needs to be removed.[/B]
This little household item can take the jet out real easy. Its part of the paperclip thingie
This is what it should look like. This one is threaded, now to find a bolt.
Found one. Look for a Regular 12mm Bolt about two inches long. I put a little bit of honda bond on the end of it and up the threads for a complete seal
Finished product
Old May 23, 2007 | 03:08 PM
Default Re: K24a1/K20a2 head oil orifice blocking question? (Nikos)
I am using a 2003 K24a1 CRV block and the oil fitting looks alot differnt its brass and it screws in ill have pics up soon
Old May 23, 2007 | 03:26 PM
Here is what it looked like in the block it was a allen but i stripped it to ****
here is what the restrictor looked like out
annother pic
Any ideas? Wierd how you had a different oil reststrictor
GSR_hatch936
Feb 3, 2008 10:20 AM
Cheivic
Nov 15, 2004 04:06 PM
95TEG
Jul 7, 2004 05:53 AM
Accord98
Aug 12, 2003 11:41 AM
VTgringo
Jun 30, 2003 07:36 PM
