b16 bottom 4 free
well i jus got a b16 bottom for free the only problem is it has a rod noc and i work in a shop so i was gona tear it apart and figure out wat the problem is and while i was at it i wanted to drop some ctr pistons and im not sure at obd it is but i have obd0 head to put that would mate no problem correct??? also i have a obd1 civic coupe so could anyone give me a rough estimate on parts that i would need to do the swap thanks
ctr means you have to mill .25 over, tear the block apart and if you need to resurface just go ctr, if not keep the pr3's
you can convert the head to obd1 with del sol vtec obd1 parts, yes the head will mate up
dizzy, i belive knock sensor, rear coolant pipe, ecu and a few ther misc things
the p30 ecu is what you need to pass BAR and you have to make sure that the b16a head is newer than the year of your car via block stamp, just tell them the motor is a jdm replacent engine that is newer than the year of your car
ok thax and i also can use axles from 99-00 and 94-00 integras and civics correct any b series basically ??? and also besides a flywheel clutch and transmission is there anything else i would need thanks
chocolatecivic
Jun 23, 2006 06:23 PM
