calling all carbon fiber guru's (need help!!!)
Old May 22, 2007 | 03:54 PM
slowkaos's Avatar
Default calling all carbon fiber guru's (need help!!!)
I drive a 95 JDM Front GSR. I have a VIS carbon fiber hood and for a long time now it has slowly been forming cracks all through the "gel coat?". Apparently the person that installed the damn hood pins did not use the correct bit to drill the holes and it cause this problem.
I need some advice on how to fix this, and if I can do it for not to much money. I have had people tell me that it could be sanded and re-gelled. But can't find anything about carbon fiber "gel coat" anywhere.
So, if anyone has some helpful advice, it would be greatly appreciated.
pics....
Old May 22, 2007 | 06:47 PM
.:Made in OC:.'s Avatar
Default Re: calling all carbon fiber guru's (slowkaos)
you would have to sand off all the old clear, and reclear it.
Old May 23, 2007 | 12:30 AM
EKFerioHawaii's Avatar
Default Re: calling all carbon fiber guru's (Made In OC)
Wow!
Those cracks are deep. I would recommend finding another hood in
better condition. Too much headaches.
Old May 23, 2007 | 04:53 AM
kiddcarbuff's Avatar
wow, ive never seen that before, definatley try to find a new hgood brosef, thats jsut asking for headaches!
Old May 23, 2007 | 05:18 AM
slowkaos's Avatar
Default Re: (kiddcarbuff)
Yeah, I was hoping I wouldn't have to get a new hood. It just seems like that might be my only choice. I might go ahead and sand it down and put a layer or two of fiberglass resin on and then just paint it....for now.
Thanks guys for the responses. If anyone else has a suggestion feel free.
Old May 23, 2007 | 10:25 AM
ST4TUS's Avatar
Default Re: (slowkaos)
New hood for sure... You could probably pick one up from Password JDM used for not too much if money is the problem
Old May 23, 2007 | 02:54 PM
Automations's Avatar
Default Re: (1MPOUND)
i can probably fix that if not make it look ten times better come on now all you have to do is call come by and see me let me look at it in person i willsee what we can do
Old May 23, 2007 | 05:39 PM
jasoncrashtech's Avatar
Default Re: (Automations)
hopefully it's not the reisin that is cracked
Old May 24, 2007 | 05:33 AM
slowkaos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Automations &raquo;</TD></TR><TR><TD CLASS="quote">i can probably fix that if not make it look ten times better come on now all you have to do is call come by and see me let me look at it in person i willsee what we can do </TD></TR></TABLE>
I keep meaning to call you. I got you cell number from Ian. I have just been crazy busy and right now money is a big issue. But I will make some time to bring it by. I have to get something done before the meet in July.
Old May 24, 2007 | 07:15 AM
electric_rex's Avatar
you could actually take a tourch and lightly go over all the cracked resin spots heating the resin until it rebonds with the side it crack from. then you would have to sand it down and reclear it. total cost?
-1 quart of clear w/ hardener $35
-prpane tourch from walmart $20
-misc. sand paper $30
- total $85
Old May 25, 2007 | 06:22 AM
slowkaos's Avatar
Default Re: (electric_rex)
Thanks guys! I might try and fix it myself if I can't come up with the money to have Automations fix it.
Thanks for the tip electric_rex! Sounds like it just might work....
Old May 25, 2007 | 08:33 AM
team1320_k26eg's Avatar
my neighbor re-cleared my cf duck bill and looks like new... $40 bucks Son...
Old May 25, 2007 | 02:35 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: (team1320_k24eg)
the way thats cracked its just too much, just get a new hood..
Old May 31, 2007 | 06:52 PM
jonnysplace's Avatar
hey you dont need to resin it if your just going to paint it .Carbon is similar to fiberglass.Just sand the cracks down make sure you feather edge them so it doesnt leave stuff theat looks like dents.Prime it with a good activated primer sand or block seal it and shoot it
Old Jun 1, 2007 | 05:21 AM
skellator_thoj's Avatar
Default Re: (jonnysplace)
if you trying to keep it clear raw carbon, then its no point to fix it because once you open up the gelcoat and put a new layer on, its going to be discolored. But if your going to paint it, you can just use bondo and paint it.
Old Jun 1, 2007 | 06:21 PM
Default Re: (skellator_thoj)
Any kind o filler is going to end up showing cracks again.Much like key scratches they still need to be sanded out.tou can use filler after if it feels wavy though
Old Jun 1, 2007 | 06:22 PM
those cracks are also to fine to absorb any kind of filler
Old Jun 7, 2007 | 06:45 AM
slowkaos's Avatar
Thanks guys for the help! I will post pics of the end result.
Lugzilla
Paint and Body
Oct 5, 2010 04:38 AM
meheartmycivic
Aug 18, 2010 03:34 PM
dumafu
Mar 3, 2006 07:19 PM
IWantaTypeRBad
Oct 11, 2002 01:29 AM
JDM_Type-R
Feb 27, 2002 06:08 AM
