crank and crank pulley???
my engine block is on a stand and I'm trying to take the crank out so I can take the block to get a new hone. Was wondering how I take the crank pulley off to get the crank out? Any ideas?
that tools goes into the crank pully, a 1/2 breaker bar holds that tool, get another breaker bar with a socket for the crank pully bolt, find a way to hold the 1/2 breaker bar so the crank pully will not turn and use the other breaker bar to break loose the bolt
i got one of those tools off ebay and it worked perfectly for me. grab a friend and have him hold one of the breaker bars. i sprayed the **** of of my crank bolt with PB blaster, i didnt want to take any chances. will take some effort as i heard these on are with around 181 ft lbs.
There are no local stores that I know of that carry this 'specialty' tool. You have to play the wait game and order it....or give the procedure in the Helms a once-over a week or two before hand to prepare for things like this. It's certainly illustrated in the Helms that you'd 'need' this tool to do what you're trying to do.
i would suggest srpaying the bolt a couple times with some kind of penetrating fluid and letting it sit. i have broken too many bolts during my swap, not fun at all to mess with.
Draggin99Si
59
Feb 20, 2005 11:59 AM
