Checked CEL but its not working?
Old May 22, 2007 | 03:13 PM
BseriesHeaven's Avatar
Default Checked CEL but its not working?
I know how to check it I put a paper clip in, but the check engine light doesn't blink. It's the SRS light that blinks and it blinks non stop the same amount of time in between each blink. i have counted up to 200 blinks... I'm confused? Any help?
Old May 22, 2007 | 03:16 PM
Mr.EM1_EK's Avatar
Default Re: Checked CEL but its not working? (BseriesHeaven)
are you jumping the right pins? just a question. which light is on the srs or the cel.
Old May 22, 2007 | 03:18 PM
Yes its the right pin. When I turn the car to the on position with the paper clip in the check engine light comes on and stays on. The SRS light blinks non stop as stated above.??
Old May 22, 2007 | 03:24 PM
94hatchling's Avatar
Default Re: Checked CEL but its not working? (Mr.EM1_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK &raquo;</TD></TR><TR><TD CLASS="quote">are you jumping the right pins? just a question. which light is on the srs or the cel.</TD></TR></TABLE>
there are only 2 pins on the connector to jump... kind of hard to mess up <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BseriesHeaven &raquo;</TD></TR><TR><TD CLASS="quote">I know how to check it I put a paper clip in, but the check engine light doesn't blink. It's the SRS light that blinks and it blinks non stop the same amount of time in between each blink. i have counted up to 200 blinks... I'm confused? Any help?</TD></TR></TABLE>
its normal for the SRS light to blink continually at the same interval when checking CELS. do you have a check engine light on when you are jumping the connector? the only time i see a solid CEL in mine was when i was test fitting a connector and i had no CEL to begin with.... interesting....
Old May 22, 2007 | 03:26 PM
Yeah when I jump the connector the Check Engine light stays solid while the srs light blinks?
Old May 22, 2007 | 03:39 PM
Anyone?
Old May 22, 2007 | 04:03 PM
Old May 22, 2007 | 08:01 PM
do you have a check engine light to begin with?
Baron55
Feb 1, 2006 08:02 AM
shreddinryguy
Jun 27, 2005 05:23 AM
carlos11
Feb 19, 2005 04:03 PM
Rick
Jul 4, 2004 08:31 AM
theslugbug
Dec 19, 2003 03:33 AM
