Eagle crank and LS crower turbo cams
Anybody have issues with those?
Cams on the first valve ( #1 exhaust ) the biggest I could set the valve is .005 mm. That with screw all the way out, the others are fine?
Eagle crank won't except my ARP flywheel bolts, it's about 3mm too long?
From: That's the wrong tone... I'm Skunk2 certified.
well, the part numbers seem correct. i would call both eagle and ARP, and ask them what's going on. the bolts will screw into the crank, they're just too long, right? will they work with a stock flywheel?
Yeah, it fits but it's about 3mm too long.
I try the bolts on another engine it works fine, I'm thinking it's the flywheel or the crankshaft. Damm aftermarkets
I will try to put on the stock flywheel...
Send them email but will call in the morning.
scrubachu
Jun 12, 2002 08:22 AM
89civic1.8T
Mar 25, 2002 08:15 AM
