Anyone got tips to crackin lug nuts off.
Old May 22, 2007 | 10:00 AM
Sassafrass's Avatar
Default Anyone got tips to crackin lug nuts off.
Seems like when I had my swap done the dude must have used an air gun and just plowed the lug nuts on to the max.
I'm outside tryin to put in my new suspension but the dam lug nuts will not budge.
I tried adding a long bar on the end of the socket wrench for some leverage but still cant budge em.
Anyone have any ideas how I can get this bastards off?
Old May 22, 2007 | 10:05 AM
instructor74's Avatar
Default Re: Anyone got tips to crackin lug nuts off. (Sassafrass)
you might be SOL if the lugs were over torqued then they might not come off. You might need an impact gun and have to brake the studs off. Then you will need to replace the studs and lug nuts. So you might want to be prepared and have them on hand to replace
BlueIntegraBoy's Avatar
How long is the bar? You should be able to remove them with a 14" breaker bar. If you have a 24" breaker bar, even better.
Old May 22, 2007 | 10:06 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Anyone got tips to crackin lug nuts off. (BlueIntegraBoy)
24" breaker bar or air tools are your best friend.
Old May 22, 2007 | 10:13 AM
BlackoutVTi's Avatar
Default Re: Anyone got tips to crackin lug nuts off. (ek forever guy)
and then kick the **** outta the 24" bar . Worked for me when my bud's 240sx had overtorqued lugnuts.
Old May 22, 2007 | 10:15 AM
lucky4586's Avatar
if you can get a long bar... more than 24" some times i use my jack handle.... 3 or 4 feet works really well just make sure you dont angle it at all
Old May 22, 2007 | 10:17 AM
Sassafrass's Avatar
Default Re: Anyone got tips to crackin lug nuts off. (BlackoutVTi)
bars not that long, I'm basically pooched now from tryin so F'n hard.
Those **** heads are on crazy. I dont even wanna try again I am afraid of what I might do. You dont even understand how frustrated I am right now.
I would kinda rather seem them break off so I can smash them to a million pieces and then **** on the remains
Old May 22, 2007 | 10:18 AM
Bakeoff's Avatar
drive to a service station and just have them back them off and put them back on. They probably won't even charge you. Get home, and pull em off.
Old May 22, 2007 | 10:19 AM
Sassafrass's Avatar
no air tools here
and right now it seems all the breaker bar is gonna do is help me smash my car out of frustration
Old May 22, 2007 | 10:20 AM
Skunk.Werks's Avatar
go to the nearest garage and ask a mechanic nicely if he will use his impact gun to take off your lug nuts and put them back on not so tight
then slip him 5$ or 10$ and say thank you
Old May 22, 2007 | 10:27 AM
WihaSi's Avatar
Try a little heat? Don't get them red hot or anything, just heat em up a bit and take a breaker bar to them.
Old May 22, 2007 | 10:33 AM
lucky4586's Avatar
Default Re: Anyone got tips to crackin lug nuts off. (WihaSi)
ok did you kick/jump on the bar. and are you should you are going the right way... not to be a dick but it happens to the best of us..."it happened to me once"lol
Old May 22, 2007 | 10:35 AM
da_dude's Avatar
Working on cars without air compressor suck ***. Good luck though.
Old May 22, 2007 | 10:40 AM
Sassafrass's Avatar
Default Re: (turb20_vtec)
Yea I triple checked I was going the right way, even made an *** of myself by asking a neighbour if I was just to make sure the fustration wasnt clouding my judgment.
I gave up, I'm not gonna have time to finsih the job now even if I got the lugs off at this point. So I'm gonna take it to a shop someplace and see if I cant get the lugs taken off as recommend above.
I dont know whey I am so nice to my car, seems like every time I try to do something on it myself it finds a way to make the job a living hell. I can only imagine how many bolts (expecially the rear LCA bolts) are gonna be wheathered on to the car and wont budge. This is why I also end up paying a shop to do things. The job is such a bitch without proper tools.
Old May 22, 2007 | 11:08 AM
Crazydave's Avatar
Default Re: (Sassafrass)
YOu need to apply a snapping force to it..
put the breaker bar on the lug... and kick down it HARD and FAST
btadler
Apr 9, 2012 02:36 PM
DB1_559
Jun 29, 2006 11:42 AM
VtecSpool
Suspension & Brakes
22
Feb 8, 2005 06:22 AM
Simple
23
Jan 23, 2004 09:28 PM
BeesDA6
Oct 13, 2003 07:01 AM
