need opinion for skunk 2 stage 2 camshafts
Old May 22, 2007 | 08:45 AM
Al-sonic's Avatar
Default need opinion for skunk 2 stage 2 camshafts
i have a stock 96 type r motor and wondering if my motor can take the skunk 2 camshafts. would my valves be able to take the camshafts.
Old May 22, 2007 | 08:55 AM
Dave_B's Avatar
Are you talking just the cams, or supporting mods too?
What is the cars current setup?
Old May 22, 2007 | 09:47 AM
w00ted's Avatar
you need valvetrain upgrade for stage 2 skunk2 cams...
Old May 22, 2007 | 10:14 AM
Al-sonic's Avatar
Default Re: (w00ted)
just the camshafts
Old May 22, 2007 | 10:59 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00ted &raquo;</TD></TR><TR><TD CLASS="quote">you need valvetrain upgrade for stage 2 skunk2 cams...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al-sonic &raquo;</TD></TR><TR><TD CLASS="quote">just the camshafts
May I suggest a LOT more reading before you jump to the conclusion that cams are going to be your one stop answer. I'd be willing to bet you don't feel a thing with just a cam upgrade (no supporting mods) and that it's not reliable at all.
Old May 22, 2007 | 12:06 PM
ZygSpeed's Avatar
Default Re: (Dave_B)
http://www.skunk2.com/index.php
Old May 22, 2007 | 09:20 PM
w00ted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
May I suggest a LOT more reading before you jump to the conclusion that cams are going to be your one stop answer. I'd be willing to bet you don't feel a thing with just a cam upgrade (no supporting mods) and that it's not reliable at all.</TD></TR></TABLE>
Stage II: Stage II profiles are more aggressive than Stage I profiles, and are designed for modified engines operating at higher rev ranges. Upgrading to Skunk2 Racing valvetrain components is required for proper operation. Stock idle and emission characteristics may be slightly compromised, but fair-to-good driveability allows them to still be used on dual-purpose vehicles. Proper tuning, an upgraded intake system, and an exhaust system are required in order to maximize the potential of these camshafts. Do not use oversized valves.
thx
Old May 22, 2007 | 09:22 PM
w00ted's Avatar
you need higher compression too...
like dave said it will be helpfull if you can tell me what is your exact setup...
Old May 25, 2007 | 09:39 AM
Al-sonic's Avatar
jdm type r motor just stock but the compression is 11 and all i have is just exhaust and intake. would it help if i put the camshaft on then taking my car to tune. will it make it safer to drive.
Old May 25, 2007 | 09:46 AM
Dave_B's Avatar
Default Re: (Al-sonic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al-sonic &raquo;</TD></TR><TR><TD CLASS="quote">jdm type r motor just stock but the compression is 11 and all i have is just exhaust and intake. would it help if i put the camshaft on then taking my car to tune. will it make it safer to drive.</TD></TR></TABLE>
I would look elsewhere for mods. Might I recommend a new Final Drive. I'd be willing to be it makes more of a difference on your car than the cams would.
Old May 25, 2007 | 02:39 PM
jj's type r's Avatar
Default Re: need opinion for skunk 2 stage 2 camshafts (Al-sonic)
i have the same setup 96itr and im going to get skunk stage 2 cams with cam gears, spring and retainers all at once. these are really good mods.
Romo Pyro
May 27, 2008 06:02 PM
team 15
Jun 1, 2007 06:18 PM
blackassasin95
57
Sep 12, 2004 01:15 PM
tkHBseries
21
Apr 13, 2004 10:12 AM
Jdmbsixteen
15
Aug 30, 2003 11:56 AM
