Hydro tranny quesion
Old May 22, 2007 | 08:29 AM
Eaglekper0046's Avatar
Default Hydro tranny quesion
I know its possible for a B-series. What about a d-series hydro tranny? The hasport kit just says B.
Old May 22, 2007 | 08:36 AM
nix94delsol's Avatar
thats wut the D16z6 is
Old May 22, 2007 | 08:41 AM
mvm's Avatar
mvm
Default Re: (crx4life90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx4life90 &raquo;</TD></TR><TR><TD CLASS="quote">thats wut the D16z6 is</TD></TR></TABLE>
I think he is asking if there is a conversion kit for his EF, Cable to Hydro. Based on what Hasport makes for the B series conversion.
CRX Toad's Avatar
Default Re: Hydro tranny quesion (Eaglekper0046)
I think he is asking how to do hyrdo conversion for D-series.
Innovative mounts has a conversion kit that works with d-series.
Old May 22, 2007 | 08:42 AM
mvm's Avatar
mvm
Default Re: Hydro tranny quesion (CRX Toad)
CRX Toad is the man !! That only took him about 2 seconds to find.
Old May 22, 2007 | 08:49 AM
Default Re: Hydro tranny quesion (mvm)
I found it right after I posted it. I was hoping for something cheaper. I can get a tranny from the junkyard for $50. But I have a $600 clutch for a hydro tranny. I still use the stock axles and motor mounts right?
Old May 22, 2007 | 10:30 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">
Innovative mounts has a conversion kit that works with d-series. </TD></TR></TABLE> So if I am hearing you correct, Innovative sells the new passenger and rear mount you would need to mount a SOHC Hydraulic transmission into our generation?
Old May 22, 2007 | 10:32 AM
CRX Toad's Avatar
Default Re: Hydro tranny quesion (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> So if I am hearing you correct, Innovative sells the new passenger and rear mount you would need to mount a SOHC Hydraulic transmission into our generation?</TD></TR></TABLE>
Let me clarify. The make a conversion kit to use a hydro D-series trans mounted in the car. So it isn't actually mounts.
Old May 22, 2007 | 10:34 AM
Let me clarify. The make a conversion kit to use a hydro D-series trans mounted in the car. So it isn't actually mounts.</TD></TR></TABLE> Ugh....
Old May 22, 2007 | 10:45 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Ugh.... </TD></TR></TABLE>
http://www.innovativemounts.co...41001
Didn't mean to get your hopes up.
Old Jun 3, 2007 | 10:51 AM
alscrx's Avatar
Do you really need new mounts when doing the d16z6 hydro tranny?? I though the mounts were the same regardless. Anyone have more info on this or any good links?
Old Jun 3, 2007 | 12:29 PM
dem0nk1d's Avatar
can't you just use the pedal assemble from a 92-95 civic or integra? I just had my 95 Eg t-boned yesterday. I have a ls motor that was being built for it, and a gsr hydro tranny
lito1208
Mar 27, 2006 12:19 PM
SinisterCRX
10
Mar 18, 2005 06:16 PM
Jonnyr4c
Feb 23, 2005 10:03 AM
REX VT
Jan 22, 2004 10:56 AM
WykidEH
19
Sep 6, 2003 06:26 AM
