90-93 DA calipers or EX swap?
Old May 22, 2007 | 06:12 AM
Red_ED8's Avatar
Default 90-93 DA calipers or EX swap?
I am currently in the middle of setting up the suspension and brakes on my 89 CRX and was looking into both of these swaps. But which will i get better braking from? I am also going to pick up a 1'in M/C and B/B and some steel braided lines. I have search both of them but nothing really set them apart to me. Thanks for the help.
Old May 22, 2007 | 06:15 AM
CRX Toad's Avatar
Default Re: 90-93 DA calipers or EX swap? (Blue_DX)
Well your not swapping calipers per se. You are swapping the entire Spindle/Knuckle of either a Integra or EX Sedan.
The Integra is longer there for you need to be lowered. The EX is the same length as your current suspension. That is the biggest difference. I personally prefer the EX way better which is the setup I have with ITR calipers.
You can also get an adapter kit from Fastbrakes to put bigger calipers on your stock parts. Which is a REALLY good way to go. http://www.fastbrakes.com Brian is a good guy and knows his stuff.
Old May 22, 2007 | 06:17 AM
REDBARON's Avatar
either or will be fine. They are practically the same. People say that the EX's are a better fit but I have the DA's and they fit just fine.
Old May 22, 2007 | 06:40 AM
Red_ED8's Avatar
Default Re: 90-93 DA calipers or EX swap? (CRX Toad)
Well thanks for the info. I guess I am going with the EX swap (found some cheap). Now just need to get some disc in the rear.
BombSquad91
Apr 18, 2014 11:46 AM
es.roadster
Feb 2, 2008 05:22 PM
Bull_head360
May 18, 2006 11:03 AM
Jonathan_ED3
15
Apr 1, 2004 09:27 AM
ijjz
Sep 2, 2002 08:17 PM
