**1993 CIVIC PUSH START PROBLEM**
Old May 22, 2007 | 04:31 AM
civic_angel's Avatar
Default ** HELP!! 1993 CIVIC PUSH START PROBLEM **
Hey! I think I have a problem with the push start on my civ. I moved it onto the street about a week ago to pull my other car in the driveway, and it suddenly doesnt want to start. I turn my key, and everything else works (stereo, lights, wipers, etc.) But when I press the start button nothing happens! If anyone has any ideas, that would be great! Im hoping to get this fixed without taking it to a mechanic, so any thoughts would be awesome!
Thanks!*
Old May 22, 2007 | 12:56 PM
H22Apowered's Avatar
Default Re: ** HELP!! 1993 CIVIC PUSH START PROBLEM ** (civic_angel)
chek the wires going into the start button switch also use a test meter to make sure that when the button is pressed power is passing through the switch .check also the starter signal fuse and if it is a 5 speed check for continuity through the safety switch on the clutch. check to make sure the wire going to the starter solinoid didnt get knocked off its post or get damaged .last but not least check to make sure the starter/solinoid its self is not bad.
Black R
Apr 8, 2023 07:14 AM
ftrms
15
Dec 22, 2010 04:05 PM
Offspring EK
22
Dec 9, 2009 04:55 PM
freshvibes
May 3, 2009 11:05 AM
91greenbeast
19
Sep 30, 2008 09:09 AM
