Alternator rubs
Old May 22, 2007 | 12:03 AM
jdmstyler's Avatar
Default Now it wont crank!
ow OK my friend has a b16 in his crx and the alternator rubs and he is using Hasport mounts. Researched but couldnt find anything anyone else know how to fix this w/o any banging or has had the same problem before. thanks in advance!
++Got the above issue fixed but now wont crank!!!
Modified by jdmstyler at 8:26 PM 5/22/2007
Old May 22, 2007 | 12:09 AM
crx_si-r's Avatar
Default Re: Alternator rubs (jdmstyler)
take the motor out, but before u do mark where it rubs. after takin it out take a sledge jammer n bang the hell out of the spot where it rubs i kno me n my buddy had to do that before we swapped in some b-series motors to have enough clearance for the alternator.
Old May 22, 2007 | 12:18 AM
Redline130's Avatar
I've heard that you can use a shorter belt so the alternator doesn't sit so far back. I can't confirm this, but it might be worth a shot. I guess it really depends how much of the alternator is rubbing the frame rail.
Old May 22, 2007 | 12:25 AM
robx7fcna's Avatar
Default Re: Alternator rubs (Redline130)
what he said, This is what I did, no banging necesary!
Old May 22, 2007 | 07:21 AM
iheartmyh0nda's Avatar
Default Re: Alternator rubs (robx7fcna)
Modified by PleaseKeepOffDunes at 8:48 AM 5/22/2007
Old May 22, 2007 | 08:14 AM
jdmstyler's Avatar
hey Rob what kinda belt does he use? he said hes looked but couldnt find one short enough?
Old May 22, 2007 | 08:23 AM
89efDUSTY's Avatar
Default Re: (jdmstyler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstyler &raquo;</TD></TR><TR><TD CLASS="quote">hey Rob what kinda belt does he use? he said hes looked but couldnt find one short enough?</TD></TR></TABLE> all you haev to do is take in your belt to the autoparts store and be like i need 1 inch or so shorter, then just adjust the alternator to sit closer to the block and the rub will dissappear. I had the same problem but i went through 2 belts before i go tthe right one
Old May 22, 2007 | 09:09 AM
sneakerfern's Avatar
Default Re: (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> all you haev to do is take in your belt to the autoparts store and be like i need 1 inch or so shorter, then just adjust the alternator to sit closer to the block and the rub will dissappear. I had the same problem but i went through 2 belts before i go tthe right one </TD></TR></TABLE>
yup yup got my belt from pepboys part number #295k4 trust me it works no banging required
Old May 22, 2007 | 09:11 AM
ludesrv's Avatar
Belts are numbered by lengths. Go to pepboys, figure out the stock number, cut your belt and see how much u need to take off to make it fit, then buy the one that is the proper length. I just banged my civic tho, much easier, less BS. Plus I didn't care about my car lol.
Old May 22, 2007 | 11:53 AM
ChickenH's Avatar
I cut a slot in my unibody about 1/4 inch wide 4 inches long and banged the body untill it was closed and welded it back up. now it clears a Big AEM pulley
Old May 22, 2007 | 03:01 PM
slowlittlewhitey's Avatar
I just used a body hammer and dented in the frame where the alternator didnt fit. Hasport even said to do this in the instructions that came with the motor mounts. Then I just used a spray can and painted the dent and you can hardly tell its there.
Old May 22, 2007 | 05:25 PM
jdmstyler's Avatar
The belt that sneakerfern said to use was Perfect. But now its not cranking over. it seems when my freind was holding a ground to it with his hands it cranked(and shocked the **** out of him) but now it doesnt crank? new post needed, huh? Any suggestions at all?? We did do another ground..
Old May 23, 2007 | 10:10 AM
jdmstyler's Avatar
bump
ITR198
Honda S2000
Jun 18, 2008 04:13 AM
92eg_b16
Jan 31, 2008 08:15 PM
rhetorical
Oct 13, 2004 02:39 PM
rasta420
28
Oct 22, 2002 02:11 PM
