Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
any special socket to remove rear lca's?
Old May 21, 2007 | 11:58 PM
Jon Vito's Avatar
Default any special socket to remove rear lca's?
i searched i couldnt find anything. those of you who have aftermarket rear lca's or have removed the stock ones is there anything special you had to use or had to get? or will any regular 12 point socket work?
Old May 22, 2007 | 12:08 AM
toyomatt84's Avatar
Sanji
I think you'll actually need an External Torx Socket.
I do not know for sure.
Old May 22, 2007 | 12:12 AM
Jon Vito's Avatar
hmm thanks, my buddy who works at honda doesnt even know lol, apparently 7th gens dont have problems in the rear so hes never had to disassemble one. reason im asking is im doing a rear disc conversion soon and i think im gonna have to unbolt them. just trying to get prepared so theres no suprises the morning i put my car up on stands and get to work
Old May 22, 2007 | 12:15 AM
toyomatt84's Avatar
Sanji
Default Re: (Jon Vito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon Vito &raquo;</TD></TR><TR><TD CLASS="quote">hmm thanks, my buddy who works at honda doesnt even know lol, apparently 7th gens dont have problems in the rear so hes never had to disassemble one. reason im asking is im doing a rear disc conversion soon and i think im gonna have to unbolt them. just trying to get prepared so theres no suprises the morning i put my car up on stands and get to work </TD></TR></TABLE>
You shouldn't have to unbolt them. The only way you would need to, is if you're replacing your LCA's. The LCA connects to the trailing arm, which then connects to the hub (which is what you're replacing).
Old May 22, 2007 | 12:33 AM
Jon Vito's Avatar
alright thanks. like i said i wasnt sure if i needed to unbolt them or not. i thought i read a long long time ago that id be using the trailing arms off of the ep3. but once again thanks for your help ill post some pics before and after when im done
Old May 22, 2007 | 01:05 AM
toyomatt84's Avatar
Sanji
Yeah, I've got the same thing going on at my place, bud. It's quite an easy swap, to be honest. Personally, even though you can maintain the proper alignment by marking the lower hub bolt, I would get the car re-aligned for the sake of being obsessive compulsive.
Old May 22, 2007 | 01:47 AM
tougEMII's Avatar
Default Re: (toyomatt84)
OCD FTW!!! lol....so we do need a special tool for the lca's? cuz im gonna pick up the skunk2 lca's as soon as they come out for our cars.
Old May 22, 2007 | 05:27 AM
bioweapon's Avatar
They are not regular sockets. Do not use one, cause if those bolts dont rotate freely, you run the risk of rounding them off, and not being able to use the proper socket. It is the external torx i believe.
Also, Megan Racing already makes an lca for our cars, theyre beefy, and I've heard nothing but good things about them.
Old May 22, 2007 | 06:10 AM
bioweapon's Avatar
Sorry I'm going to correct myself, went outside and looked, it is a 10 point bolt, not a torx.
Upon further investigation, there is a socket specifically designed for 01-05 Civic/RSX lca bolt. It should be less than $30, however from honda, it probably costs a considerable amount. Part number is 69330. Good luck.
http://www.kparts.com/shop/hon...eabea
Old May 22, 2007 | 08:53 AM
Jon Vito's Avatar
just bookmarked that site going to be ordering the socket on payday
and yeah im going to do the alignment i love having access to an alignment rack :-)
greenCRV
May 17, 2006 10:00 AM
B96v6
10
Dec 24, 2005 05:55 PM
desmarais
Dec 20, 2005 09:54 PM
ekcivic9
Sep 30, 2005 06:55 PM
91sicrxer
21
Jun 14, 2005 04:19 PM
