Anyone know the stock GSR Bpipe diameter? What should I use?
Does anyone know the size of the stock B pipe on a GSR? What would be a good B pipe to get to go with my Axle Back N1? Thanks!!
B Pipe, Noun, Be Pie-p - The piping that goes between your axle back and Cat..
By the way, the Axle Back has 2.5in piping and its a straight though design.
Edit : ok, Mod changed my title... there goes my chance of an answer
[Modified by KooKaT, 1:24 PM 6/2/2002]
I think you'd have a better chance for an answer with a subject that matches your question.
GS-R b-pipe is is 1.9-2.0"
The right size header-cat-exhaust system depends on your power goals. Pretty much all aftermarket systems are 2.25-2.36". That size is fine for a bolt-ons only setup on a regular Integra. Type R's need a bigger exhaust in their bolt-ons setups.
EDIT: Those measurements are on the outer diameter. The standard 16g steel has a wall thickness of .065".
[Modified by SurferX, 1:16 PM 6/2/2002]
